GPS module + PIC
Results 1 to 13 of 13
Threaded View
  1. #5
    Default Check Sum
    Here is one check sum solution for gps:
    gpsdata         var byte[82]       ' Max length of a GPS sentence is 82 bytes.
    DoCS:
        i = 0                             ' Initialize the position counter
        WHILE gpsdata[i] != "*"           ' Count everthing until the *
            cs = cs ^gpsdata[i]           ' XOR for checksum
            i = i + 1                     ' Increment position counter
        WEND
        ' A quick and easy atoh function
        ' Make it a seperate label if we add more atoh conversions in the future
        LOOKDOWN gpsdata[i+1],["0123456789ABCDEF"],tempbyte
        gpscs = tempbyte * 16
        LOOKDOWN gpsdata[i+2],["0123456789ABCDEF"],tempbyte
        gpscs = gpscs + tempbyte
        ' Flag bad data "V" if checksum doesn't add up.
        ' Or if the sentence is less then 20 chars long
        ' Which means there is no active waypoint to go to.
        ' Should be "A" otherwise.
        IF (cs != gpscs) OR (i < 20 )THEN
              gpsvalid = 0
              gpsvalid = 1
