GPS module + PIC
Results 1 to 13 of 13
    You need an inverter chip or circuit . (MAX232)
    SWITZERLAND (french speaking)
    Thanks Dave,
    The MAX232 in my drawer did the trick
    Any idea about the checksum calculation?
    This is what I did up to now in EXCEL but trying to convert HEX to BIN will rise an error.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=4178&stc=1&d=127089284 5">
    Roger
    is the number excel failed on but other than that I do not know. I will have to look into it.
    Default Check Sum
    Here is one check sum solution for gps:
    gpsdata         var byte[82]       ' Max length of a GPS sentence is 82 bytes.
    DoCS:
        i = 0                             ' Initialize the position counter
        WHILE gpsdata[i] != "*"           ' Count everthing until the *
            cs = cs ^gpsdata[i]           ' XOR for checksum
            i = i + 1                     ' Increment position counter
        WEND
        ' A quick and easy atoh function
        ' Make it a seperate label if we add more atoh conversions in the future
        LOOKDOWN gpsdata[i+1],["0123456789ABCDEF"],tempbyte
        gpscs = tempbyte * 16
        LOOKDOWN gpsdata[i+2],["0123456789ABCDEF"],tempbyte
        gpscs = gpscs + tempbyte
        ' Flag bad data "V" if checksum doesn't add up.
        ' Or if the sentence is less then 20 chars long
        ' Which means there is no active waypoint to go to.
        ' Should be "A" otherwise.
        IF (cs != gpscs) OR (i < 20 )THEN
              gpsvalid = 0
              gpsvalid = 1
    Default Can't "talk" towards my GPS module...
    - Reading & parsing NMEA sentences is ok;
    - Calculating checksum is ok;
    - Sending data to GPS module is not ok.
    I have connected the GPS module via the MAX232 chip to my serial PC port both ways so I should be able to "talk" to my module.
    Unfortunately, only reading out (receiving) the GPS module is working.
    I checked the MAX chip with my oscillo and the signals are okay (TX & RX) on both levels (RS232 and TTL).
    I'm sending an example from the module's datasheet to enable a VTG sentence but it won't work.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=4205&stc=1&d=127141338 1">
    I just never see this VTG data appear.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=4207&stc=1&d=127141381 2">
    Any idea?
    Roger
    Default It works now!
    Strange....
    I just restarted the terminal and... it works now - I can sent messages to the module.
    Must be a kind of magic (?)
    Roger
    Is it Hyperterminal?
