SHIFTIN SHIFTOUT timing problem
Results 1 to 14 of 14
    Mar 2011
    Los Angeles, California
    Default Still Confused
    My guess is that Brian is busy? I was wondering if anyone would know how to do the PIC pin assignments? Several things have me lost such as in the code there is only 1 reference to the sensor's MCLK pin? Mostly I am familiar with using:
    ' ** Declare Pins Used **
    Sclk Var PortB.0
    Din Var PortB.1
    This code has me completely lost!
    Thanks in advance, eventually it will all come back to me, Ed
    Default Intersema issues
    Hi Ed,
    Yes you do need a set of hardware defines such as
    MClk VAR PortC.1
    SClk VAR PortC.4
    MClk in my design is driven by CCP2 so it cannot be randomly assigned but any of the other Intersema pins can be attached to any PIC pins.
    YOU, and only you, can write the hardware defines as they are dependent on how you have laid out your circuit board.
    Or have I missed your question?
    HTH
    BrianT
    Mar 2011
    Default Re: SHIFTIN SHIFTOUT timing problem
    Thanks Brian!
    Yes I noticed that depending upon the PIC there is only one pin marked as CCP2. My guess is that by using HPWM the PIC knows to use this pin and it still must have a hardware definition? MCLK is shown as a comment so it has been confusing to know what to do for the hardware defines. Another thing I did not understand is why use CCP2 and not CCP1?
    For 3.3 v to 5.0 v conversion (bi-directional) a device that does this known as the ADG3304 if this is of value. The device can also be used for other voltage level changes.
    Variations in atmospheric pressure causes the zero reference point (the surface of the water) to change so to maintain accuracy a simple water detector (two transistors) could be used to set the zero reference (surface) point.
    Thanks for answering and hope I have made some small contribution to you and others.
    Ed
    Mar 2011
    Default A little help with understand the code in this post Please
    A little help please.
    high presspwr ' there is no pin defined as presspwr
    temp2 = 1000 - celsius ' there is no variable named temp2
    d[17] = temp2.byte0
    d[18] = temp2.byte1 ' There is no array named d.
    high pgc ' there is no pin defined as pgc
    gosub shutdownmemory ' there is no sub-routine with this name
    gosub lowestpower ' there is no sub-routine with this name either end '
    I do not wish it to stop or end just continue to get int information.
    Thanks, Ed
    If that is so, then pick one and make it so, some thing like
    presspwr var PortA.0
    temp2 var word 'a byte only holds 0-255
    d[17] = temp2.byte0
    assigns value to 2 bytes in array, set up array,
    d var byte[18]
    again make a pin do this by assigning it to that duty
     pgc var PortA.1 ' or some other unused pin
    Make a sub directory or remove the call to it and send the code elsewhere using
    goto or gosub as appropriate.
    same answer as above. this is the disadvantage to using code you did not write, you are forced into the position of clairvoyant as you try to imaging what the programmer envisioned.
    Probably the best argument for chewing through someone else's code is to learn from it, the cost is the frustration of trying to understand it.
    I hope you found something useful in my rant,
    JS
