![Quote](images/misc/quote_icon.png)
Originally Posted by
jellis00
I will try to post the code in another posting.
Pause 10 ' This statement is placed at beginning of code for ICD use
'Configuration Fuses
ASM ; 18F2550/4550, 8mhz crystal
__CONFIG _CONFIG1L, _PLLDIV_2_1L & _CPUDIV_OSC4_PLL6_1L & _USBDIV_2_1L
__CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H
__CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
__CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
__CONFIG _CONFIG3H, _PBADEN_OFF_3H ; PortB resets as digital
__CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
' Define Hardware / Set Registers
DEFINE OSC 16
DEFINE I2C_SLOW 1 ' Set i2c to the standard speed
DEFINE I2C_HOLD 1 ' Enable recieving i2c device to pause communication
Include "Modedefs.Bas"
INCLUDE "ALLDIGITAL.pbp"
INCLUDE "DT_INTS-18.bas"
INCLUDE "ReEnterPBP-18.bas"
TRISA = 0 ' PortA output connections used for LCD interface
TRISB = %00001100 ' RB2 & RB3 set as RTC Alarm1 & Alarm2 inputs
' PORTB.2 is an input from switch grounding
' PORTB.4 is used during test as a Green LED heartbeat
' and as a USB connected indicator during ops
TRISC.1 = 0 ' PORTC.1 used during test as a RED LED output
TRISC.2 = 0 ' PortC.2 is used for the LCD R/W connection
'Declare Variables, Aliases & Constants
day_cnt VAR BYTE ' Counter for day number during monthly epoch
ext_pwr VAR PORTC.0 ' Alias to control power to Ultrasonic sensors
i VAR Byte ' Index in FOR-NEXT loops
J VAR BYTE ' Index to EEPROM address for avg. range store
LED_RED VAr PortC.1 ' Red LED used to indicate battery is low
LED_GRN VAR PortB.4 ' Green LED used to indicate USB connected
rng0 VAR w0.Byte0 ' LSB of range measurement when right justified
rng1 VAR w0.byte1 ' MSB of range measurement when right justified
SCL VAR PORTB.1 ' I2C clock pin
SDA VAR PORTB.0 ' I2C data pin
Spare_1 VAR PORTB.7 ' PGD for ICSP & Spare I/O for normal ops
Spare_2 VAR PORTB.6 ' PGC for ICSP & Spare I/O for normal ops
w0 var word ' W0 is the word value of the range data
' Constants
RTCdevice CON $D0 ' Device write address = %11010000 for RTC
srfdevice CON $E0 ' Device address for SRF02 ultrasonic RangeFinder
Vthr CON 46 ' Threshold (3.3v) triggers battery low voltage
'SETUP FOR USING DS1337 Real Time Clock
'Initialize LEDs to off
LOW LED_GRN
LOW LED_RED
GOSUB InitializeDisplay ' Initialize LCD before starting mainloop
GOSUB SetTimeAndDate ' Set RTC time/date before starting mainloop
' START SUBROUTINES
GOTO JumpPoint ' Jump over all subroutines
InitializeDisplay:
' Blink LED_GRN twice to indicate entered IntializeDisplay
For i = 0 to 1
HIGH LED_GRN
Pause 500
LOW LED_GRN
PAUSE 500
Next
' Saving characters by eliminating in post
SetTimeAndDate: ' Subroutine to set current time, date and alarm
' Blink LED_GRN 3X times to indicate entered SetTimeAndDate
For i = 0 to 2
HIGH LED_GRN
Pause 500
LOW LED_GRN
PAUSE 500
Next
' END OF SUBROUTINES
JumpPoint:
'Initialize epoch indexes on powerup/reset
day_cnt = 0
WRITE 9, day_cnt ' Store new epoch initialized day_count
Pause 20
J = 0 ' Initialize index at EEPROM start address
WRITE 10,J ' Store new epoch initialized J index
Pause 20
' SETUP FOR INTERRUPTS
;INT_Handler USB_Handler
INT_Handler INT2_INT, _Range, PBP, yes
' Per DT, DT_INTS already takes care of setting INTCON and RCON registers
' but this doesn't work unles INTCON2 set per below:
INTCON2 = %10000000 ' Set INT2 for falling edge (Bit4-low)
' on RTC's interrupt.
' Disable all PortB pull-ups (Bit7-high)
RTC_INT_FLG VAR INTCON3.1 'INT2 interrupt flag from RTC..DT_INTS handles
@ INT_ENABLE INT2_INT ; enable external (INT) interrupts
LOW ext_pwr ' Turn off power to SRF02 until I2C bus is needed again
' Begin Main Program Loop
mainloop:
PAUSE 100 ' Without this Pause, there's nothing to keep the WDT clear.
' HIGH, LOW & GOTO don't generate CLRWDT instuctions.
HIGH LED_GRN ' Blink LED_GRN during main loop
' Place code here to put MCU and Ultrasonic Ranger in SLEEP mode.
' while waiting for clock interrupt to wakeup from SLEEP mode.
' Awaiting interrupt from RTC
PAUSE 1000
LOW LED_GRN ' Turn off LED_GRN as Heartbeat during mainloop
Pause 900
Goto mainloop ' Do it forever
' Begin Interrupt Handler
Range:
' Blink LED_RED 3X to indicate entered Range ISR
For i = 0 to 2
HIGH LED_RED
Pause 500
LOW LED_RED
PAUSE 500
Next
@ INT_RETURN
'End of Interrupt Handler
