Is a good way connect more MCLR between them?
Results 1 to 1 of 1
Threaded View
    Feb 2007
    Default Is a good way connect more MCLR between them?
    it 's a good thing to use the output of the MAX232 DTR to reset the PIC for the bootloader, and use it for more PIC on the same board?
    At present, each PIC has its own 4.7K pull-up resistor and its reset button to tie to GND.
    Can I connect together all the MCLR pins?
    In this way every push button pressed, or DTR change reset all the PIC.
    What appens if I try to program one pic with a programmer like EPIC?
    Ciao
    Leo
