2 LCD Displays, one Pic
Results 1 to 11 of 11
    Aug 2003
    Default 2 LCD Displays, one Pic
    Hi Guys,
    So I would like to connect 2 seperate identical LCD modules to the same pic.
    Do I just connect everything in parallel except the contrast and enable pins,
    then just toggle the enable pins to select which display I'm talking to?
    Art, I have done just that in the past for a few projects, except I have 1 enable line that is dedicated to the enable port pin declaired with 2 resistors of 1 K ohm value connected to the enable line from the processor. Then each of the other resistor legs get connected to the respective display enable lines. Then I just used 2 remaining processor pins connected to the the display enable lines respectivly, these pins would be held low and set as outputs. Now to communicate to a display you just set the respective (enable) pin to an input state then send the lcd commands to that display. The other display will keep its former displayed material as it's (enable) line would be held low.
    Darrel had done this but cannot find the link in the forum.
    If he gets back on-line I am sure he will post it.
    Sure I will ...
    Two LCDs on one PIC
    http://www.picbasic.co.uk/forum/show...=2388#post2388
    Maximun Cable Length for PIC to LCD
    http://www.picbasic.co.uk/forum/showthread.php?t=7596
    <img src="http://www.picbasic.co.uk/forum/picture.php?albumid=1&pictureid=4" />
    malc-c's Avatar
    malc-c Guest
    Nice neat breadboarding there DT
    Aug 2003
    Cheers, that's about how I expected it would work except for the trick with the resistors.
    Art, What Darrel shows is what I was talking about....
    Aug 2003
    No wI'm wondering why you'd use 3 pins to control 2 Enable signals?
    Why not just use one pin per LCD Enable pin, and manually set each one high
    to talk to each LCD display?
    Because LCD's are sent data "Synchronously".
    Which means that the data is Clocked in with a pulse, and that pulse is on the Enable line.
    For a 4-bit interface, it takes two clocks per byte.
    So the Enable lines must be controllable by LCDOUT, and LCDOUT can only control one.
    The other two Disable outputs simply keep the "Clock" from getting to that display.
    hth,
    Art, think of the two extra lines as a CS (Chip Select) line of the LCD to be active.
    Aug 2003
    Ah, never mind, I thought the Enable pin was simply held high to talk to the LCD.
    I guess I thought wrong.
