TTL magnetic card reader reads but unprintable char
Results 1 to 4 of 4
    dima shawahneh's Avatar
    dima shawahneh Guest
    Unhappy TTL magnetic card reader reads but unprintable char
    hello every one
    I have TTL card reader connected with pic18f4620 on port B
    Im using the driver found with picc compiler (ex_mcr)
    which is supposed to read magnetic card correctly
    the problem that it reads , but the data are not correct --> not printable characters
    like this..(w??n?]??)
    I have been searching but finding nothing to help
    the number of characters is also not correct.
    I tried many different magnetic cards but nothing worked well.
    here is the code..
    this is the driver
    // Redefine the following pins in
    // the main file as needed.
    #ifndef MCR_CARD_PRESENT
    #define MCR_CARD_PRESENT   PIN_B0
    #define MCR_DATA1          PIN_B1
    #define MCR_STROBE1        PIN_B2
    #define MCR_DATA2          PIN_B4
    #define MCR_STROBE2        PIN_B5
    #endif
    // The following define the error codes.
    // To check for a specific error, check
    // the cooresponding bit in the value
    // returned by mcr_read().
    #define MCR_ERR_PARITY1 1
    #define MCR_ERR_PARITY2 2
    #define MCR_ERR_LRC1    4
    #define MCR_ERR_LRC2    8
    // Date:       7/28/2003
    int mcr_read(char* track1, char* track2)
       int   error    = 0;
       int1  dataBit  = 0;
       int1  ST1      = 1;
       int1  ST1_old  = 1;
       int1  firstOne1= 0;
       int1  parity1  = 0;
       int   count1   = 0;
       int   index1   = 0;
       int   LRC1     = 0;
       int1  ST2      = 1;
       int1  ST2_old  = 1;
       int1  firstOne2= 0;
       int1  parity2  = 0;
       int   count2   = 0;
       int   index2   = 0;
       int   LRC2     = 0;
       // Wait for card to be present
       while(input(MCR_CARD_PRESENT))
       // printf("outside\n");
        restart_wdt();
       // Loop until a card is not present
       while(!input(MCR_CARD_PRESENT))
         // printf("inside\n");
          restart_wdt();
          // Check for NULL pointer and an index less than 79
          if(track1 != 0 && index1 < 79)
             // Get strobe number one
             ST1 = input(MCR_STROBE1);
             restart_wdt();
             // If the strobe was high and is now low (falling edge),
             // then data is present
             if(ST1 == 0 && ST1_old == 1)
                ST1_old = 0;
                // Check if the first 1 was received
                if(firstOne1 == 1)
                   // Check if 6 bits of data were received
                   if(count1 == 6)
                      // Set the data bit count back to 0
                      count1 = 0;
                      // Shift the bits right by 2
                      *(track1+index1) >>= 2;
                      // Verify the LRC
                      if(*(track1+index1-1) == '?' && LRC1 != *(track1+index1))
                         error |= MCR_ERR_LRC1;
                         LRC1 ^= *(track1+index1);
                      // Add 0x20 to convert to ASCII
                      *(track1+index1) += 0x20;
                      // Check the parity bit. The parity on a space is not checked
                      // because of the trailing zeros after the LRC character
                      if(!input(MCR_DATA1) != parity1 && *(track1+index1) != ' ')
                         error |= MCR_ERR_PARITY1;
                      // Reset the parity check
                      parity1 = 1;
                      // Increment the index into the array
                      ++index1;
                      // Get a bit of data from the card
                      dataBit = !input(MCR_DATA1);
                      // XOR the data with the parity bit
                      parity1 ^= dataBit;
                      // Store the new bit of data
                      shift_right(track1+index1, 1, dataBit);
                      // Increment the bit counter
                      ++count1;
                   // Check if the first 1 has appeard on the data line
                   if(!input(MCR_DATA1))
                      // Set the first 1 received flag
                      firstOne1 = 1;
                      // Store the first 1
                      shift_right(track1, 1, 1);
                      ++count1;
             else if(ST1 == 1)
                ST1_old = 1;
          // our code
     //     printf("%c\n",track1[index1]);
        //  if(track1[index1]=='?')
        //    return error;
          // Check for NULL pointer and an index less than 40
          if(track2 != 0 && index2 < 40)
             // Get strobe number 2
             ST2 = input(MCR_STROBE2);
             if(ST2 == 0 && ST2_old == 1)
                ST2_old = 0;
                if(firstOne2 == 1)
                   // Check if 4 bits of data were received
                   if(count2 == 4)
                      // Reset the bit counter back to 0
                      count2 = 0;
                      // Shift the bits right by 4
                      *(track2+index2) >>= 4;
                      // Verify the LRC
                      if(*(track2+index2-1) == '?' && LRC2 != *(track2+index2))
                         error |= MCR_ERR_LRC2;
                         LRC2 ^= *(track2+index2);
                      // Add 0x30 to convert to ASCII
                      *(track2+index2) += 0x30;
                      // Check the parity bit. The parity on a 0 is not checked
                      if(!input(MCR_DATA2) != parity2 && *(track2+index2) != '0')
                         error |= MCR_ERR_PARITY2;
                      parity2 = 1;
                      ++index2;
                      dataBit = !input(MCR_DATA2);
                      parity2 ^= dataBit;
                      shift_right(track2+index2, 1, dataBit);
                      ++count2;
                   if(!input(MCR_DATA2))
                      firstOne2 = 1;
                      shift_right(track2, 1, 1);
                      ++count2;
             else if(ST2 == 1)
                ST2_old = 1;
       // Return any errors
       return error;
    Any suggestions ...
    thanks alot
    Sep 2005
    Campbell, CA
    One suggestion:
    Write the code in PBP and ask again if that doesn't work.
    Charles Linquist
    There's even a Mag Card Reader example on the MeLabs website.
    Talking change the calculator Batt or clean glasses ???
    Wrong forum, may be ...
    BUT
    Wasn't the Magic number 48d or 0x30 ???
    just my 2 cents ...
