HELP with Year counter
Results 1 to 2 of 2
    sanatana's Avatar
    sanatana Guest
    Default HELP with Year counter
    Hello Everyone
    I Need some of your expert help in solving my problem.
    This what i am trying to do.
    I want to be able to tell when 365 days has being reach on my data logger
    I am using Pic18F452 and my Timer1 has already being used for a different task so i can't use that.
    i am now trying to use the 1Hz pulse coming from my DS1307 connected to RB0 interupt pin.
    But the problem is a word variable can only hold 65536 counts which is just over 18 hours but i want to count 24 hours
    18x 60x60 =64800
    24x60x60=86400
    The idea is that if i can be able to to know when 1 day is reached all i have to do to check for when a year
    has reached is to know when 365 days has being reached.
    Hope to get your help
    Santana
    can i do something like this or any simpler way any of you might have would be much appreciated
    DAY VAR WORD
    TEMP_COUNT VAR WORD ' Count for 18 hrs
    OVER_COUNT VAR WORD' Count for 6 hrs
    DAY =0
    TEMP_COUNT=0
    OVER_COUNT=0
    'MAIN PROGRAM HERE
    AGAIN:
    GOSUB GET_ALARM
    GOSUB GET_TEMP
    GOSUB GET_TIME
    gosub Get_Batt
    @ SLEEP
    PAUSE 200
    GOTO AGAIN
    ' Interrupt handler
    MYINT:
    IF INTCON.1=1 Then
    TEMP_COUNT=TEMP_COUNT+1
    WHILE
    TEMP_COUNT= > 64800 ' COUNT TO 18 HRS
    OVER_COUNT= OVER_COUNT+1 ' IF 18HRS REACHED THEN START COUNT NEXT 6 HOURS
    WEND
    IF OVER_COUNT=21600 THEN
    DAY = DAY +1
    TEMP_COUNT=0 ' RESET COUNTERS
    OVER_COUNT=0 ' RESET COUNTER
    INTCON.1=0 ' Clear RB0 interrupt flag
    nested variable and if then... try this
    second var byte
    minute var byte
    hours  var byte
    day    var word
    year   var byte
    clear
    disable
    Myint:
        IF INTCON.1=1 Then
           if second<60 then
              second=second+1
              second=0
              if minute<60 then
                 minute = minute + 1
                 minute = 0
                 if hours < 24 then
                    hours = hours + 1
                    hours = 0
                    if day<365 then
                       day=day+1
                       day = 0
                       year = year + 1
    enable
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Counter not counting !!!
    Last Post: - 20th February 2009, 22:15
  3. Replies: 42
    Last Post: - 14th January 2008, 11:38
  4. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 05:02
  5. Microcontroller with 2 way paging application problem
