i'll second Darrel on that. AND i'll still stick to say
DEFINE HSER_BAUD 31250
NOT A VALID BAUDRATE IMHO.
BUT
DEFINE HSER_TXSTA 90h
DEFINE HSER_RCSTA 24h
DEFINE HSER_SPBRG 39 'set baudrate to 31250
BUT
I checked the version on my laptop and it has a RETURN at the end of each subroutine
If you use RETURN then you need to use GOSUB to get to these routines instead of GOTO.
31250 is a common "MIDI" data rate.
Actually, they where not just typos, the first two where legitimate mistakes, but I caught them myself (that's what happens when you do this stuff at 1:00am) on the last one I was using a return at the end of each subroutine, but as Darrel and Bruce pointed out, I needed to use Gosub instead of a Goto, so I fixed all the mistakes, but it still does not work, so then I tried Steve's suggestion and changed the DEFINE HSER_BAUD to DEFINE HSER_SPBRG 39, but it still made no difference, incidentally, DEFINE HSER_BAUD 31250 works fine on the 16F628, so I would think it should work on the 16F688 also.
Here is the revised code, any other suggestions would be appreciated.
Code:' PicBasic file for midi footpedal interface using a Pic16F688 ' set osc to HS when programming DEFINE OSC 20 ' tell program we are using a 20mhz oscillator DEFINE HSER_RCSTA 90h ' enable hardware serial port DEFINE HSER_TXSTA 24h ' enable high speed transmit DEFINE HSER_BAUD 31250 ' set the baud rate for MIDI communications DEFINE ADC_BITS 10 ' set the number of bits in the sample DEFINE ADC_SAMPLEUS 50 ' set the sample time TRISA = %00111111 ' Set PORTA to inputs TRISC = %00101111 ' set PORTC to inputs ANSEL = %11110000 ' enable analog 4,5,6,7 the rest as digital ADCON0 = %10000001 ' set VREF to VDD and right justify result ADCON1 = %00100000 ' set conversion clock FOSC/32 CMCON0 = 7 ' turn off comparitors OPTION_REG.7 = 0 ' enable internal pull-ups on porta WPUA = %00000111 ' enable individual pull-ups on porta 0,1,2 C0 Var word ' create C0 to store result from Volume pot C1 Var word ' create C1 to store result from Expression pot C2 Var word ' create C2 to store result from Foot Controller pot C3 Var word ' create C3 to store result from Portamanto Time pot vol Var byte ' create variable for volume exp Var byte ' create variable for expression foo Var byte ' create variable for foot controller por Var byte ' create variable for portamento time volout Var byte ' create variable for volume output expout Var byte ' create variable for expression output fooout Var byte ' create variable for foot controller output porout Var byte ' create variable for portamento time output sw1 Var byte ' create variable to hold switch1 value (sustain on/off) sw2 Var byte ' create variable to hold switch2 value (portamento on/off) loop: ADCIN 4,C0 ' read Volume pot and place value in C0 vol = C0 / 8 ' convert reading to a midi value from 1-127 If vol <> volout Then ' check to see if the value has changed volout = vol HSEROUT [176,7,volout] ' send Volume out serial port as midi information Endif ADCIN 5,C1 ' read expression pot and place value in C1 exp = C1 / 8 ' convert reading to a midi value from 0-127 If exp <> expout Then ' check to see if the value has changed exp = C1 HSEROUT [176,11,expout] ' send exptession out serial port as midi information Endif ADCIN 6,C2 ' read foot controller pot and place value in C2 foo = C2 / 8 ' convert reading to a midi value from 0-127 If foo <> fooout Then ' check to see if the value has changed fooout = foo HSEROUT [176,4,fooout] ' send foot controller out serial port as midi information Endif ADCIN 7,C3 ' read portamento time pot and place value in C3 por = C3 / 8 ' convert reading to a midi value from 0-127 If por <> porout Then ' check to see if the value has changed porout = por HSEROUT [176,5,porout] ' send portamento time out serial port as midi information Endif If porta.0 = 0 Then gosub sw1on ' check sustain pedal If porta.0 = 1 Then gosub sw1off If porta.1 = 0 Then gosub sw2on ' check portamento pedal If porta.1 = 1 Then gosub sw2off If porta.2 = 0 Then Hserout [255] ' reset all controllers Endif Goto Loop ' go back to continuous monitoring sw1on: If sw1 = 0 Then ' check to see if sustain is off sw1 = 127 Hserout [176,64,sw1] ' turn on sustain Endif return sw1off: If sw1 = 127 Then ' check to see if sustain is on sw1 = 0 Hserout [176,64,sw1] ' turn off sustain Endif return sw2on: If sw2 = 0 Then ' check to see if portamento is off sw2 = 127 Hserout [176,65,sw2] ' turn on portamento Endif return sw2off: If sw2 = 127 Then ' check to see if portamento is on sw2 = 0 Hserout [176,65,sw2] ' turn off portamento Endif return
Hiya Dave,
Glad to see I didn't scare you off.
Here's a couple things that might be causing problems, but I don't really see one that will cause it not to work at all.
The sw1on: etc. sections make tests that require the value to be either 0 or 127. Any other value will cause that section to stop functioning.
Since the variables can be any value on power-up, nothing will ever happen. If you put a CLEAR statement at the top of the program it would fix that, but it might be better to change the way it works so that odd values won't cause a problem.
Also in this section:I think you wanted it like this...Code:ADCIN 5,C1 ' read expression pot and place value in C1 exp = C1 / 8 ' convert reading to a midi value from 0-127 If exp <> expout Then ' check to see if the value has changed exp = C1 HSEROUT [176,11,expout] ' send exptession out serial port as midi information Endif
That's all I see at this point, but I'm still looking.Code:ADCIN 5,C1 ' read expression pot and place value in C1 exp = C1 / 8 ' convert reading to a midi value from 0-127 If exp <> expout Then ' check to see if the value has changed expout = exp HSEROUT [176,11,expout] ' send exptession out serial port as midi information Endif
Best regards,
Darrel
Hi Darrel,
If I couldn't take a little criticism for stupid mistakes, I would never have posted this here.
The switches are specifically setup that way so that the program will only send a MIDI command when there is a change in the switch position, otherwise it would send an on or off command on every cycle. I am using the same code on the 16F628 and it works exactly the way I want it to. I added a command to set the values to 0 (MIDI-Off) on power-up, but it made no difference.
Another thing that I find weird is that if I don't erase the the 16F688 before programming, it comes up with a bunch of errors. I think I'll have to go back to the beginning, start with a few LEDs, then add some switches .... and work my way up from there, just to make sure the chips I have are OK.
Problem solved.
I have been talking with Charles at Micro Engineering Labs, and we figured out what the problem was. On the 16F688, if the oscillator does not start up properly, then the chip will revert to using the internal oscillator, which is why my program worked fine if you disabled the serial port. My oscillator was fine but one of the capacitors was bad, after replacing the cap, the serial port worked fine. Once I could view the output, I found I had to tweek a few settings to get everything working the way I wanted it to. I had to set TMR0 to internal, otherwise PORTA.2 would not work properly, and add a small delay after reading the ADCs, to stablize the output. For those of you who are interested, here is the revised WORKING!! code.
Thanks for everyones help.
Code:' PicBasic file for midi footpedal interface using a Pic16F688 ' set osc to HS when programming DEFINE OSC 20 ' tell program we are using a 20mhz oscillator DEFINE HSER_RCSTA 90h ' enable serial receive DEFINE HSER_TXSTA 24h ' enable serial transmit DEFINE HSER_BAUD 31250 ' set baud rate for MIDI transmission DEFINE ADC_BITS 10 ' set the number of bits in the sample DEFINE ADC_SAMPLEUS 50 ' set the sample time TRISA = %00111111 ' Set PORTA to inputs TRISC = %00101111 ' set PORTC to inputs CMCON0 = 7 ' turn off comparitors ANSEL = %11110000 ' enable analog 4,5,6,7 the rest as digital ADCON0 = %10000001 ' set VREF to VDD and right justify result ADCON1 = %00100000 ' set conversion clock FOSC/32 OPTION_REG = %01011111 ' enable internal pull-ups on porta and set TMR0 to internal WPUA = 7 ' enable individual pull-ups on porta 0,1,2 C0 Var word ' create C0 to store result from Volume pot C1 Var word ' create C1 to store result from Expression pot C2 Var word ' create C2 to store result from Foot Controller pot C3 Var word ' create C3 to store result from Portamanto Time pot vol Var byte ' create variable for volume exp Var byte ' create variable for expression foo Var byte ' create variable for foot controller por Var byte ' create variable for portamento time volout Var byte ' create variable for volume output expout Var byte ' create variable for expression output fooout Var byte ' create variable for foot controller output porout Var byte ' create variable for portamento time output sw1 Var byte ' create variable to hold switch1 value (sustain on/off) sw2 Var byte ' create variable to hold switch2 value (portamento on/off) sw1 = 0 ' set pedals to off on power-up sw2 = 0 Loop: ADCIN 4,C0 ' read Volume pot and place value in C0 pause 20 vol = C0 / 8 ' convert reading to a midi value from 1-127 If vol <> volout Then ' check to see if the value has changed volout = vol HSEROUT [176,7,volout] ' send Volume out serial port as midi information Endif ADCIN 5,C1 ' read expression pot and place value in C1 pause 20 exp = C1 / 8 ' convert reading to a midi value from 0-127 If exp <> expout Then ' check to see if the value has changed expout = exp HSEROUT [176,11,expout] ' send expression out serial port as midi information Endif ADCIN 6,C2 ' read foot controller pot and place value in C2 pause 20 foo = C2 / 8 ' convert reading to a midi value from 0-127 If foo <> fooout Then ' check to see if the value has changed fooout = foo HSEROUT [176,4,fooout] ' send foot controller out serial port as midi information Endif ADCIN 7,C3 ' read portamento time pot and place value in C3 pause 20 por = C3 / 8 ' convert reading to a midi value from 0-127 If por <> porout Then ' check to see if the value has changed porout = por HSEROUT [176,5,porout] ' send portamento time out serial port as midi information Endif If porta.0 = 0 Then gosub sw1on ' check sustain pedal If porta.0 = 1 Then gosub sw1off If porta.1 = 0 Then gosub sw2on ' check portamento pedal If porta.1 = 1 Then gosub sw2off If porta.2 = 0 Then ' if PANIC button is pressed Hserout [255] ' reset all controllers Pause 1000 Endif Goto Loop ' go back to continuous monitoring sw1on: If sw1 = 0 Then ' check to see if sustain is off sw1 = 127 Hserout [176,64,sw1] ' turn on sustain Endif return sw1off: If sw1 = 127 Then ' check to see if sustain is on sw1 = 0 Hserout [176,64,sw1] ' turn off sustain Endif return sw2on: If sw2 = 0 Then ' check to see if portamento is off sw2 = 127 Hserout [176,65,sw2] ' turn on portamento Endif return sw2off: If sw2 = 127 Then ' check to see if portamento is on sw2 = 0 Hserout [176,65,sw2] ' turn off portamento Endif return
