resonator question
Results 1 to 2 of 2
    Question resonator question
    Will a ceramic resonator work across a wide voltage range such as 3V? . I have some in stock that have been used at 5V only. The spec. sheet only shows a test circuit using 5V. No mention of other electrical specifications. If 3V is OK what about 1.8V.? Thanks
    I have used them down to 2.5 volts. No problems.... if they are slow enough.
