hein? since awhile i didn't heard about CodeLite....i was in love with this editor in the past... auto code completion was one of my favorite option... but CodeLite is still only a text editor... BTW
I just realized that my 16F877 is probably running at 20MHZ.
Probably or is running at 20MHZ...look on the crystal. If nothing works it can be few things
  • 1. you didn't set HS oscillator when programming
    2. you didn't add DEFINE OSC 20 at the top of your code
    3. you didn't select the right device version into your programmer utility
and some others
