Interfacing to Wii Nunchuck
Results 1 to 13 of 13
    Mar 2010
    Default Re: Interfacing to Wii Nunchuck
    BTW- This is not in anyway work related. Just something I thought I could do at home that might also get my 9 year old son involved in electronics also.
    Larry
    Aug 2008
    Portugal
    Hi;
    I made this program one year ago. This program aquires receive the data from Nunchuck and then acording to some "if", some data is sent to the serial port.
    Maybe you can see how it works, and use it with some modification.
    Try to find the label "Nunchuck" at the end of the program, that is the routine that receive the data from the nunchuck.
    Code
    '*  Name    : NUNCHUCK RF.BAS                                   *
    '*  Author  : [Hugo Oliveira]                                   *
    '*  Notice  : Copyright (c) 2010                                *
    '*  Date    : 09-07-2010                                        *
    '*  Notes   : BreadBoard                                        *
    '*          : PIC16F628A                                        *
    include "modedefs.bas"
    DEFINE I2C_HOLD 1
    @ DEVICE pic16F628A, INTOSC_OSC_NOCLKOUT
    @ DEVICE pic16F628A, WDT_OFF
    @ DEVICE pic16F628A, PWRT_OFF
    @ DEVICE pic16F628A, MCLR_OFF
    @ DEVICE pic16F628A, BOD_OFF
    @ DEVICE pic16F628A, LVP_OFF
    @ DEVICE pic16F628A, CPD_OFF
    @ DEVICE pic16F628A, PROTECT_OFF
    '                               VARIÁVEIS
    Jx var byte
    Jy var byte
    Ax var Byte
    Ay var byte
    BE var bit
    BD var bit
    buffer var byte[6]
    '                       REGISTOS PINOUT 1 = IN; 0 = OUT
             '76543210
    TRISA  = %00000000
    TRISB  = %00000010
    CMCON = 7
    VRCON = 0
    '                              NOMES PINOUT
    LED    VAR PORTA.1
    TX     Var PORTB.2
    RX     VAR PORTB.1
    SDA    var PORTB.4
    SCL    var PORTB.5
    '                              DEFENIÇÕES
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 2
    DEFINE DEBUG_BAUD 19200
    DEFINE DEBUG_MODE 0
    '                             INICIO PROGRAMA
    Start:
     HIGH LED
     PAUSE 500
     LOW LED
     PAUSE 500
     HIGH LED
     PAUSE 500
     LOW LED
     PAUSE 500
     HIGH LED
     GOSUB NUNCHUCK
    '                             JoyStick Eixo X
      if JX>70 and JX<=100 then
       'SEROUT TX,T9600,["%TE"]
       DEBUG "%TE"
       pause 20
       if JX>0 and JX<=70 then
       'SEROUT TX,T9600,["%TE1"]
       DEBUG "%TE1"
       pause 20
      if Jx>180 and Jx<210 then
       'SEROUT TX,T9600,["%TD"]
       DEBUG "%TD"
       pause 20
      if Jx>=210 then
       'SEROUT TX,T9600,["%TD1"]
       DEBUG "%TD1"
       pause 20
    '                             JoyStick Eixo Y
      if JY>70 and JY<=100 then
       'SEROUT TX,T9600,["%TB"]
       DEBUG "%TB"
       pause 20
      if JY>0 and JY<=70 then
       'SEROUT TX,T9600,["%TB1"]
       DEBUG "%TB1"
       pause 20
      if Jy>180 and Jy<210 then
       'SEROUT TX,T9600,["%TC"]
       DEBUG "%TC"
       pause 20
      if Jy>=210 then
       'SEROUT TX,T9600,["%TC1"]
       DEBUG "%TC1"
       pause 20
    '                             Axis -  Eixo X
      if Ax<100 then
       'SEROUT TX,T9600,["%TE2"]
       DEBUG "%TE2"
       pause 20
     if Ax>140 then
       'SEROUT TX,T9600,["%TD2"]
       DEBUG "%TD2"
       pause 20
    '                             Axis -  Eixo Y
      if Ay<110 then
       'SEROUT TX,T9600,["%TB2"]
       DEBUG "%TB2"
       pause 20
      if Ay>140 then
       'SEROUT TX,T9600,["%TC2"]
       DEBUG "%TC2"
       pause 20
    '                             Botões
      IF BE = 0 then
       'SEROUT TX,T9600,["%RL1"]
       DEBUG "%RL1"
       pause 80
      IF BD = 0 then
       'SEROUT TX,T9600,["%RD1"]
       DEBUG "%RD1"
       pause 80
    goto Main
    '                      SUB ROTINA - LEITURA DADOS NUNCHUK
    NUNCHUCK:
     i2cwrite sda,scl,$A4,$40,[$00]
      pause 10
     i2cwrite sda,scl,$A4,[$00]
      pause 10
     i2cread sda,scl,$A5,[STR buffer\6]
      pause 10
     Jx=(buffer[0] ^ $17)+ $17
     Jy=(buffer[1] ^ $17)+ $17
     Ax=(buffer[2] ^ $17)+ $17
     Ay=(buffer[3] ^ $17)+ $17
     buffer[5]=((buffer[5] ^ $17)+ $17 )
     if (buffer[5] & $01) <> 0 then
       BE=1
       BE=0
     if (buffer[5] & $02) <> 0 then
       BD=1
       BD=0
    Thanks and Regards;
    Gadelhas
    Mar 2010
    Thanks Gadelhas,
    I finished wiring up the Wii components last night and will hopefully get a chance to play with the I2C this weekend. I looked through your code and it seems as straight forward as I thought. I will post here or start a new thread once I get this project going.
    Larry
    Aug 2008
    Portugal
    ok, post your results when you have them!
    Thanks and Regards;
    Gadelhas
