Is there a speed limit using CodeLite
Results 1 to 3 of 3
    Feb 2005
    Indiana
    Default Is there a speed limit using CodeLite
    I just realized that my 16F877 is probably running at 20MHZ.
    Is there a set-up in CodeLite to set the PIC Speed or will I need the Full Version?
    John
    JRudd
    hein? since awhile i didn't heard about CodeLite....i was in love with this editor in the past... auto code completion was one of my favorite option... but CodeLite is still only a text editor... BTW
    Probably or is running at 20MHZ...look on the crystal. If nothing works it can be few things
    • 1. you didn't set HS oscillator when programming
      2. you didn't add DEFINE OSC 20 at the top of your code
      3. you didn't select the right device version into your programmer utility
    and some others
    Feb 2005
    Indiana
    Default Setting OSC Speed
    Thanks Man,
    It was your item 2. I wasn't setting the correct Osc Speed, in this case 20MHZ. DEFINE OSC 20
    jrudd
    JRudd
  1. USB Speed
    By Rony in forum USB
    Last Post: - 24th August 2008, 21:43
  2. USB Speed
    By Rony in forum General
    Last Post: - 21st August 2008, 23:15
  3. Closed loop speed controller
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 26th January 2008, 15:15
  4. NEWB Help HPWM coding
    By Seafurymike in forum mel PIC BASIC Pro
    Last Post: - 1st January 2008, 22:52
  5. Replies: 14
    Last Post: - 26th September 2007, 06:41
