Don't be discouraged. I'm using an 18F8723 connected to any number of 18F2221s. The 2221's are remote sensors (temperature, humidity) and are very small. They couldn't generate any heat otherwise they would screw up the readings, so I run them on their internal oscillators at 4MHz to keep the power low. The sensors use the internal EUSART for receive, but have to shut the EUSART off to transmit, since I needed an open-collector transmitter, and the hardware (without an outboard FET, at least) is incapable of running open-collector. In order to meet my timing criteria, I needed to run 19.2Kbaud (for system timing reasons). Serout2 can't run 19.2 at 4Mhz, but DEBUGOUT does. The problem is - DEBUGOUT doesn't have an open-collector option, so I modified PBPPIC18.LIB to give me a debugout open-collector option. That works.
The sensors have a HSERIN interrupt running. When a character comes in, and there is an address match, the DEBUGOUT is invoked (it is also inside the ISR) and the response is sent. When not in the ISR, the PIC is continuously polling its temperature and humidity sensors.
The whole thing works very well, and has been tried with over 150' of cabling and 8 sensors.
