Osctune
Results 1 to 36 of 36
Thread: Osctune
    Default Re: Osctune
    you're sending a start bit, 8 bits of data and a stop bit all encoded as one symbol ie 10 bits .
    @say 9600 symbols per sec that yields a bit time of 10.4uS.
    how and what are you measuring ?
    logic probe ? do you mean logic analyser
    have you left off the start or stop bit in your calcs ?
    10 bits @ 10.4uS /bit = 9600 baud
    9 bits @ 10.4uS /bit = 10000 baud
    Default Re: Osctune
    I'm measuring using Saleae Logic software.
    It reports the values I mentioned when using autobaud to detect the rate.
    https://www.saleae.com/downloads.
    I used to have this working but the problem is I don't know if it is the transmitter Hserout or receiver plx-daq is not working?
    The data looks correctly constructed with the logic analyser monitoring it.
    My config for reference is
    __CONFIG _CONFIG1H, _OSC_INTIO67_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOREN_OFF_2L & _BORV_3_2L
    __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    __CONFIG _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_OFF_3H
    __CONFIG _CONFIG4L, _STVREN_OFF_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
    __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    __CONFIG _CONFIG7H, _EBTRB_OFF_7H
    DEFINE OSC 32 '32mhz Clock
    OSCCON = %01110000 'Internal 32 mhz Osc and stable
    OSCTUNE = %01000000 'Enable PLL 8mhz x 4
    WDTCON = %00010101 'Set watchdog Timer for 1 second
    CMCON = %00000111 'Comparators Off
    CVRCON = %00000000 'CvRef Powered Down
    CCP1CON= %00001100 'CCP1 Module PWM Mode
    CCP2CON= %00000000 'CCP2 Module Disabled
    HLVDCON= %00000000 'HLVCON Disabled
    T1CON = %00110000 '$30 = Prescaler 1:8, TMR1 OFF
    TRISA = %00001011 'SET PORTA0, A1 & A3 AS INPUTS, REST AS OUTPUTS
    TRISB = %00000000 'SET PORTB AS OUTPUTS
    TRISC = %10011000 'SET PORTC AS OUTPUTS EXCEPT PORT C3,C4 & C7
    ADCON0 = %00000001 'SETUP ADC & ENABLE ADC MODULE on AN0
    ADCON1 = %00001110 'SETUP ADC SET REFV to VDD & VSS AN0
    ADCON2 = %00100010 'SETUP ADC FOSC/32 LEFT JUSTIFY TAD 8
    DEFINE LCD_DREG PORTB 'PORTB is LCD data port
    DEFINE LCD_DBIT 0 'PORTB.0 is the data LSB
    DEFINE LCD_RSREG PORTC 'RS is connected to PORTC.0
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTC 'EN is connected to PORTC.1
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 8 '8 lines of data are used
    DEFINE LCD_LINES 4 'It is a 4-line display
    DEFINE LCD_COMMANDUS 1500 'Use 1500uS command delay
    DEFINE LCD_DATAUS 44 'Use 44uS data delay
    DEFINE ADC_BITS 8 'Set number of bits in result
    DEFINE ADC_CLOCK 3 'Set Clock source (3 = rc)
    DEFINE ADC_SAMPLEUS 50 'Set sampling time in uS
    DEFINE CCP1_REG PORTC 'HPWM channel 1 pin Port C Backlight PWM Driver
    DEFINE CCP1_BIT 2 'HPWM channel 1 pin Bit 2
    DEFINE HSER_SPBRG 51 ' 38400 Baud @ 32MHz, 0.16%
    SPBRGH = 0
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
    Default Re: Osctune
    Closure on my problem. I found the reciever i was using wanted idle low data not idle high... Arrrggggg.. I was sure it was high..
    Thanks for the advice. The transmitter was working correctly after all..
