Get a bit or set a bit
Results 1 to 5 of 5
    Miami, Florida USA
    Normnet,
    I can use select case but something like the following would be nice.
    You can use some of the code that you posted. Except that I would do the increment from 0 to 7 instead of the other way. But, all depends on what you are trying to do. What exactly are you trying to do?
    VAR   X   BIT[8]
    For I = 0 to 7
    X[I] = varBYTE.I
    next
    For I = 0 to 7
    varBYTE.I = X[I]
    next
    Bitbang.
    Works OK with select case but not with posted code.
    Need to get each bit from a send byte and set pin to TX or
    read a pin and set a bit in receive byte to RX.
    Bitbang sends/reads bit 7 first.
    Norm
    Sep 2005
    Campbell, CA
    I haven't tried it, but -
    Variable.0[X] = Y
    Should work
    Charles Linquist
    Variable.0[X] = Y
    Works fine!
    Norm
