No problem, and thanks.
I'm sorry you hadn't seen it already.
I guess we'll have to fix that problem.
Thanks a lot guys, yes that was the way that i found on the Internet, the command-line was a bit different but was the same process.
this is what i got: when i compile the program a window appear showing: "searching for the programmer" the computer search for a bit and nothing happened, so time for me to forget this way to do it.
So I tried the exporting hex method suggested, i went to the PBP and found the "blink.hex" file after i erase the pic+blank check procedures (doing it form the pickit2 software) theses are the results.
-exported the file, the display shown: hex file successfully imported
-so i clicked on write: the display shown: programming successful
-then i click verify: verification of program memory failed at address 0x000000
So seem like something is obviously not right, sorry for all this dumb questions, and i appreciate your patience
Do you have code protect checked?
