Time mismatch in PAUSEUS
Results 1 to 7 of 7
    May 2008
    Italy
    Try these three lines of asm code should give you 1 microsec delay @ 20 MHz. (Just experimenting with some simple asm code to break the ice)
    @ goto	$+1
    @ goto	$+1
    @ nop
    Al.
    Dec 2008
    New York US
    Lightbulb
    Hi Al,
    Thank you very much for your advice. Will test.
    It is all about Tips & Tricks, so will learn step by step.
    Visual Basic was more friendly.
    Best Regards
    Here is an ASM code generator for delays.
    http://www.piclist.com/techref/picli...egen/delay.htm
    VB... May have been friendly but you were not working at the hardware level either...
    Dec 2008
    New York US
    Dear Al,
    So I tested your modified code and get result:
    PORTB = % 10000001 '2 clock cycles x .2uSec =.4uSec
    @ goto $+1	   '2 clock cycles x .2uSec =.4uSec Skip next istr
    @goto $-1	   '2 clock cycles x .2uSec =.4uSec Return on prev address
    @nop  		   '3 clock cycles x.2uSec = .6uSec
    So total is equal 1.8uSEc what I really get
    Finally I come with decision to drop @nop
    So it looks now more affordable:
    Total is 1.2 uSec that is closer to what I espected.
    Thank you again for driving me in right direction.
    Best Regards
    May 2008
    Italy
    You are welcome.
    Al.
