ADC and power consumption
Results 1 to 5 of 5
    Was the battery voltage divider in circuit before the ADC command was added and the first measurments taken?
    Leave the code as is and disconnect the divider from the battery and see if that makes a difference.
    Miami, Florida USA
    bogdan,
    That voltage divider alone is using 45 uAmps all the time. Also, why are you using resistors R5, R9, and R10? If you have these ports set to high then you would have more current leaking in there.
    Default reply / thx
    No, the voltage divider circuit wasn`t there when i measured 42uA
    It is going back to 42uA
    R5, R9, and R10
    = pulldown resistors for unused pins
    Thank You for your help ...
    Default what about now ?
    In order to reduce the power consumption it is a good idea to use a common emitter transistor circuit for the voltage divider (as in the attachment) ?
    I will
    High PortA.1
    during the ADC reading/conversion
    Best Regards,
    Bogdan
