Error messages
Results 1 to 8 of 8
Thread: Error messages
    Jul 2006
    Lazio, Italy
    Default thanks
    Yes, the chip selected is correct and also with your program it gives me the same error using the ICD COMPILE PROGRAM or only COMPILE PROGRAM, I stated in my previous post that I use for my projects demoborad QL 200 and its programmer connected to my PC via USB. Perhaps this could be the problem? However the list of errors that gave me compiling your program:
    -------------------- PROGRAM ---------------------
    @ __CONFIG _CONFIG1H,_OSCS_OFF_1H & _XT_OSC_1H
    @ __CONFIG _CONFIG2L,_BOR_OFF_2L & _PWRT_ON_2L
    @ __CONFIG _CONFIG2H,_WDT_OFF_2H
    @ __CONFIG _CONFIG3H,_CCP2MX_OFF_3H
    @ __CONFIG _CONFIG4L,_STVR_OFF_4L & _LVP_OFF_4L
    DEFINE OSC 4 ' Clock a 4 Mhz
    DEFINE ADC_BITS 8 ' Set number of bits in result
    DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
    DEFINE LCD_BITS 4 'NUMERO LINEE DI COMANDO 4 O 8
    DEFINE LCD_DREG PORTB 'PORTA ChE GESTISCE LCD
    DEFINE LCD_DBIT 4 'BIT INIZIALE BUS
    DEFINE LCD_RSREG PORTC 'PORTA CHE GESTISCE RS
    DEFINE LCD_RSBIT 5 'BIT CHE GESTISCE RS
    DEFINE LCD_EREG PORTB 'PORTA CHE GESTISCE E
    DEFINE LCD_EBIT 3 'PIN CHE GESTISCE IL SEGNALE E
    DEFINE LCD_LINES 2 'NUMERO LINEE LCD
    Addr VAR BYTE
    Value VAR BYTE
    Addr = 0
    Value = 123
    WRITE Addr, Value
    READ Addr, Value
    LCDOUT $FE,1,"Addr=",DEC Addr," Value=",DEC Value
    STOP
    --------------- ERROR MESSAGES----------------------
    ERROR: Macro WRITEADDRESS?B not found in macro file.
    ERROR: Macro WRITE?B not found in macro file.
    ERROR: Macro READADDRESS?B not found in macro file.
    ERROR: Macro READ?B not found in macro file.
    Question
    Hi, mombasa
    Just pasting your program into MCS compiles fine ( success 532 Bytes ) ...
    soooo ... did you verify in the compiler options you point to the correct PBP2.60 location ???
    Jul 2006
    Lazio, Italy
    Default thanks
    Acetronics thanks for your interest, but after several attempts, I must conclude that MCS is not fully compatible with Windows 7. In fact I noticed that with other operating systems, error messages are not generated. I'll try again and will let you know the results. Thanks and regards.
    Quote Originally Posted by mombasa View Post
    ... but after several attempts, I must conclude that MCS is not fully compatible with Windows 7. ...
    MicroCode Studio works with Win7. It just takes a few more steps sometimes.
    Especially if it's Win7-64.
    Try this ...
    http://www.picbasic.co.uk/forum/show...21&postcount=4
