Which PIC are you using?
Does it have any EEPROM onboard?
Some PIC's don't have any, and will give those errors.
Darrel, thanks for your answer, it is my honor and great pleasure that you interest to my problem, so I learned a lot from your routine that have enriched our much loved PICBASIC, the pic I use is the 18f252 with internal 256 byte EEPROM.
I don't see a reason then.
Do you have the correct chip selected in the Device Drop-down in MicroCode Studio?
Does this program (that compiles here with PBP 2.60/18F252), give you the same error?
<br>Code:Addr VAR BYTE Value VAR BYTE Addr = 0 Value = 123 WRITE Addr, Value READ Addr, Value LCDOUT $FE,1,"Addr=",DEC Addr," Value=",DEC Value STOP
Yes, the chip selected is correct and also with your program it gives me the same error using the ICD COMPILE PROGRAM or only COMPILE PROGRAM, I stated in my previous post that I use for my projects demoborad QL 200 and its programmer connected to my PC via USB. Perhaps this could be the problem? However the list of errors that gave me compiling your program:
-------------------- PROGRAM ---------------------
@ __CONFIG _CONFIG1H,_OSCS_OFF_1H & _XT_OSC_1H
@ __CONFIG _CONFIG2L,_BOR_OFF_2L & _PWRT_ON_2L
@ __CONFIG _CONFIG2H,_WDT_OFF_2H
@ __CONFIG _CONFIG3H,_CCP2MX_OFF_3H
@ __CONFIG _CONFIG4L,_STVR_OFF_4L & _LVP_OFF_4L
DEFINE OSC 4 ' Clock a 4 Mhz
DEFINE ADC_BITS 8 ' Set number of bits in result
DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
DEFINE LCD_BITS 4 'NUMERO LINEE DI COMANDO 4 O 8
DEFINE LCD_DREG PORTB 'PORTA ChE GESTISCE LCD
DEFINE LCD_DBIT 4 'BIT INIZIALE BUS
DEFINE LCD_RSREG PORTC 'PORTA CHE GESTISCE RS
DEFINE LCD_RSBIT 5 'BIT CHE GESTISCE RS
DEFINE LCD_EREG PORTB 'PORTA CHE GESTISCE E
DEFINE LCD_EBIT 3 'PIN CHE GESTISCE IL SEGNALE E
DEFINE LCD_LINES 2 'NUMERO LINEE LCD
Addr VAR BYTE
Value VAR BYTE
Addr = 0
Value = 123
WRITE Addr, Value
READ Addr, Value
STOP
--------------- ERROR MESSAGES----------------------
ERROR: Macro WRITEADDRESS?B not found in macro file.
ERROR: Macro WRITE?B not found in macro file.
ERROR: Macro READADDRESS?B not found in macro file.
ERROR: Macro READ?B not found in macro file.
Hi, mombasa
Just pasting your program into MCS compiles fine ( success 532 Bytes ) ...
soooo ... did you verify in the compiler options you point to the correct PBP2.60 location ???
Acetronics thanks for your interest, but after several attempts, I must conclude that MCS is not fully compatible with Windows 7. In fact I noticed that with other operating systems, error messages are not generated. I'll try again and will let you know the results. Thanks and regards.
MicroCode Studio works with Win7. It just takes a few more steps sometimes.
Especially if it's Win7-64.
Try this ...
http://www.picbasic.co.uk/forum/show...21&postcount=4
