Error messages
Results 1 to 8 of 8
Thread: Error messages
    Jul 2006
    Lazio, Italy
    Default Error messages
    I ask you help please, when I try to launch ICD COMPILE PROGRAM microcode STUDIO PLUS use with PBP Pro 2.6 and MPASMWINI get the following error messages:
    ERROR: Macro WRITEADDRESS? B not found in macro file.
    ERROR: Macro WRITE? B not found in macro file.
    ERROR: Macro WRITEADDRESS? C not found in macro file.
    ERROR: Macro WRITEADDRESS? W not found in macro file.
    ERROR: Macro READADDRESS? C not found in macro file.
    ERROR: Macro READ? B not found in macro file.
    ERROR: Macro READADDRESS? B not found in macro file.
    ERROR: Macro READ? W not found in macro file.
    ERROR: Macro READADDRESS? W not found in macro file.
    May I know what's going on? Thanks and regards
    Which PIC are you using?
    Does it have any EEPROM onboard?
    Some PIC's don't have any, and will give those errors.
    <br>
    Jul 2006
    Lazio, Italy
    Default thanks
    Darrel, thanks for your answer, it is my honor and great pleasure that you interest to my problem, so I learned a lot from your routine that have enriched our much loved PICBASIC, the pic I use is the 18f252 with internal 256 byte EEPROM.
    I don't see a reason then.
    Do you have the correct chip selected in the Device Drop-down in MicroCode Studio?
    Does this program (that compiles here with PBP 2.60/18F252), give you the same error?
    Addr  VAR BYTE
    Value VAR BYTE
    Addr = 0
    Value = 123
    WRITE Addr, Value
    READ Addr, Value
    LCDOUT $FE,1,"Addr=",DEC Addr,"  Value=",DEC Value
    STOP
    <br>
    Jul 2006
    Lazio, Italy
    Default thanks
    Yes, the chip selected is correct and also with your program it gives me the same error using the ICD COMPILE PROGRAM or only COMPILE PROGRAM, I stated in my previous post that I use for my projects demoborad QL 200 and its programmer connected to my PC via USB. Perhaps this could be the problem? However the list of errors that gave me compiling your program:
    -------------------- PROGRAM ---------------------
    @ __CONFIG _CONFIG1H,_OSCS_OFF_1H & _XT_OSC_1H
    @ __CONFIG _CONFIG2L,_BOR_OFF_2L & _PWRT_ON_2L
    @ __CONFIG _CONFIG2H,_WDT_OFF_2H
    @ __CONFIG _CONFIG3H,_CCP2MX_OFF_3H
    @ __CONFIG _CONFIG4L,_STVR_OFF_4L & _LVP_OFF_4L
    DEFINE OSC 4 ' Clock a 4 Mhz
    DEFINE ADC_BITS 8 ' Set number of bits in result
    DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
    DEFINE LCD_BITS 4 'NUMERO LINEE DI COMANDO 4 O 8
    DEFINE LCD_DREG PORTB 'PORTA ChE GESTISCE LCD
    DEFINE LCD_DBIT 4 'BIT INIZIALE BUS
    DEFINE LCD_RSREG PORTC 'PORTA CHE GESTISCE RS
    DEFINE LCD_RSBIT 5 'BIT CHE GESTISCE RS
    DEFINE LCD_EREG PORTB 'PORTA CHE GESTISCE E
    DEFINE LCD_EBIT 3 'PIN CHE GESTISCE IL SEGNALE E
    DEFINE LCD_LINES 2 'NUMERO LINEE LCD
    Addr VAR BYTE
    Value VAR BYTE
    Addr = 0
    Value = 123
    WRITE Addr, Value
    READ Addr, Value
    STOP
    --------------- ERROR MESSAGES----------------------
    ERROR: Macro WRITEADDRESS?B not found in macro file.
    ERROR: Macro WRITE?B not found in macro file.
    ERROR: Macro READADDRESS?B not found in macro file.
    ERROR: Macro READ?B not found in macro file.
    Question
    Hi, mombasa
    Just pasting your program into MCS compiles fine ( success 532 Bytes ) ...
    soooo ... did you verify in the compiler options you point to the correct PBP2.60 location ???
