16F876A Pulsin issues
Results 1 to 16 of 16
    Wink
    Hi, Rob
    Consider all inputs are clamped to Vcc + .6 v ... ( take care: clamps diodes are very Weeeeeeak ! )
    so, the best is not to have more than Vcc ... or use strong external clamp diodes ( 1 N4148 i.e )
    but analog inputs can rise to Vref + 2v ... not forgetting Vcc+.6v is an absolute maximum ...
    Mar 2010
    Would adding a bigger load to the pack solve the problem? A bigger load should pull the cells down to 1.2v per cell to give me a max of 4.8V on a fully charged pack? perhaps a 500ma load?
    Wink
    Bad Idea ...
    just use a voltage divider in the input ...
    1/2 is the easiest to find ( 2 equal 1% resistors ) ...
    2/3 is still easy ( 1 k and 2k resistors @ 1%)
    Installing a load that can draw 300 - 400 mA on demand is rather a good thing ...
    But think regulator doesn't output EXACT 5.000 v ... so measure it and enter value as a parameter for calculations ...
    Mar 2010
    I have an idiot grin on my face, :-) im making some really good progress, I have the pulse in now displaying on the screen (strange from a JR Rx Im getting a range from 560 - 990 from the pulsin) and have the ability to jump to a servo test (sweep from side to side) at the push of a button, :-)
    My ADC is sort of working, with the voltage divider I'm getting 2.54V on my DMM, however if I display the ADC input Im only seeing 2 and not the .54 (obviously this will be multiplied by 2 once i get the decimals). I have tried:
    lcdout $FE, $C0+8, dec volt
    and
    lcdout $FE, $C0+8, # volt
    but still only get the first digit. Is this due to the ADC VAR being a "WORD"
    Volt    Var     WORD
    ADCIN 4, volt
    My Vref from the regulator is 5.00V on my DMM
    Not sure im getting this whole ADC concept, I;ve read another one of Melanie's posts and from what I can work out, my RAW ADC in variable should be as follows:
    if my Vref = 5.00 then if my ADCIN was exactly 5.00V the ADC result would give me 1024, however I am giving a ADC of 2.54 I should get a value in the variable of 520? however I am displaying a single digit "2" on the LCD with the code above, not sure how to do the math on this.
    Mar 2010
    Ah, ok, finally, im a git, :-)
    Im now reading a 520 adc value with the battery on and the DMM measuring 2.54 (Needs to be multiplied by 2 to reverse the voltage divider effect).
    Err, something not right, im missing something with the math:
        ADCIN 4, volt                  ' Read AN4 into temp variable
        Vin = (5*volt/1024)       ' Convert to voltage assuming 5.00 = 1024
    lcdout $FE, $C0+8, dec Vin,".",dec2 Vin,"V"
    pulling out many hairs, :-( my biggest issue is that even in school my maths was not great, spose thats why Excel was invented, for people like me, :-)
    Mar 2010
    just not getting the decimal places now, :-(
    Latest attempt
    volt = volt * 2
    Vin = (5*volt/1023)
    Vind = (volt // 1000) / 10 'millivolts?
    lcdout $FE, $C0+8, dec Vin,".",dec2 Vind,"V"
    Time to pack it in for the night, work tomorrow, fairly good progress, just the decimal points to figure out.
    Kind Regards
    Rob
    Mar 2010
    Am I on the right track?
    the "//" operator will store the remainder in the chosen Var, thus:
    volt = volt * 2                 'Correct the ADCin for the Voltage divider?
    FVolt = (5*volt/1023)
    MVolt = (5*volt // 1023)  'millivolts?
    lcdout $FE, $C0+8, dec FVolt,".",dec4 MVolt,"V"
    Sorry for getting overly complex with this but trying to understand how it works, I have been able to simulate what I need to do in excel, just not sure if the above will work in PBP:
    D1 = Vref @ 5.00
    D5 = Adc Corrected @ 1021
    D6 = 10 bit ADC @ 1024
    D14 = Whole number (Formula =TRUNC(D9,0), result = 4
    D15 = Remainder (Formula =(MOD((D5*D1)/D6,1)*1000)), result = 990
    I could then LCDout D14, ".", D15 in theory if the formula in PBP equaled the excel result.
    not sure though, still a bit confused
    Cheers
    Rob
    Wink
    Quote Originally Posted by Bobbo_ZA View Post
    Latest attempt
    volt = volt * 2
    Vin = (5*volt/1023)
    Kind Regards
    Rob
    Ok Rob,
    What about :
    volt = volt * 2 * 5
    Volt = 100*volt               ' See manual for DIV32 !!!
    Vind = DIV32 1024           ' Here we have result in 1/100 Volts ...
    Vin = Vind/100                  ' Here we get the integer part ...
    Vind = Vind // 100             ' Here we get the decimal part ...
    that's all !
