DS1307 accuracy
Results 1 to 17 of 17
Thread: DS1307 accuracy
    Today if I have a production run of say 1000 pcs of a new product needing an RTC, I can earn an extra $750 in return for two hours worth of programming - I'll do it. Wouldn't you?
    Yup, now to get that 1000 part run.
    Aug 2003
    Melanie, I remember you bagging them in another RTC thread.
    My use of Maxim/Dallas RTCs is 0.056 per year, but that figure might be rising
    I wonder if the calender on the RTC can solve the problem of converting UTC time to a local time where the date is different for part of the day.
    Best example is it's 1:00 am, 1st of March but to convert to local time I might
    have to decrement the date and be left wondering if it is a leap year, etc.
    Does the possibility exist of using the RTC to test for a valid date just by trying to set it?
    The date at the end of the month is automatically adjusted for months with fewer than 31 days, including corrections for leap year.
    Does that help?
    The DS3231 also has an internal crystal.
    But the tolerance is +/-2 PPM, which is about 1 minute / year.
    DS3231 - Extremely Accurate I²C-Integrated RTC/TCXO/Crystal
    http://www.maxim-ic.com/quick_view2.cfm/qv_pk/4627/t/al
    Extract from my routine for setting T&D... for convenience, I set YEAR, then MONTH and finally DAYS... here I set the maximum number of Days you can increment the DAY count to...
    		RTCDayMax=31
    		If RTCMonth=4 then RTCDayMax=30
    		If RTCMonth=6 then RTCDayMax=30
    		If RTCMonth=9 then RTCDayMax=30
    		If RTCMonth=11 then RTCDayMax=30
    		If RTCMonth=2 then
    			RTCDayMax=28
    			If (RTCYear&03)=0 then RTCDayMax=29
    Stupidly, the DS1307 can be set for Day 55 in month 55 in year 55. It's just a brainless incremental counter that checks for validity once it rolls past midnight. So you CAN have a DAY of total rubbish before it becomes sensible.
    Well yes... you CAN convert UTC (say from a GPS Data-stream) to Local Time at any part of the globe... the Time difference is simply 1 HOUR per 15 Degrees rotation away from the Prime Meridian (which you can also get from the GPS). It's actually based on 15 Degree wide BANDS the centres of which are 15 Degrees apart from the Prime Meridian. The trouble is, the Great-Circle Meridians comprising the Band edges have been skewed in many parts of the world to maintain the same Local Time across for example whole groups of Pacific Islands or other geographic anomalies which otherwise would put an odd corner of a country or region into another Time Zone. So whilst you CAN easilly work out EXACT LOCAL TIME based on Longitude, without actually containing a Database to correct for the odd skew here and there, you're pretty much, well... skewed!
    And then of course you need a Second Database, to hold Daylight Savings information, because different parts of the world have different Dates (and Times) that they switch. The UK for example just had their Summer-Time switch at 2am last Sunday morning. Other parts of the world have already had it - some yet to have it... don't you just love Time? Such a simple subject (dividing the rotation of the planet into equal increments), yet made so complex...
    Finally we get to the good folks that need to pray at Sunrise and Sunset... with published Tables and Charts of the exact time of the event based on where on the Globe you happen to lay down your prayer mat. Did any one of the great scholars that compile these charts stop and think that Sunrise and Sunset is effected by ELEVATION and if you happen to be at the bottom of a North-South running mountain range on the Western side at Sunrise or the Eastern side at Sunset affects the outcome quite CONSIDERABLY? Nope! Anybody know if it messes your chances of getting to Heaven if you get it wrong?
