I got error if we used pbp260 complier
Results 1 to 6 of 6
    May 2005
    Default I got error if we used pbp260 complier
    I got many error with my code if we used pbp260 complier
    but if change to pbp247 my code can pass complier
    what is differance between 2 version
    Quote Originally Posted by chai98a View Post
    Tell us what the errors are. The biggest difference which will cause a failure to compile is using the label " Loop " OK in 2.47 not OK in 2.6
    You may have commented out the Default configs in 2.47 and will have to do so all over in 2.6
    May 2005
    thank , where i can get detail of pbp260 pls...
    Talking
    Hi, Chai
    Of course : in your Holy Manual ... that ( thanks to God ) hasn't been published on the web, to the day ...
    PS: I compiled your code you gave in another thread ... no problem.
    So ...
    1) is it the same code we talk about ???
    2) Can you explain the " problem" somewhat further with usable détails ???
    Melanie edited out original Post and the Quote to the Link
    If that really is the manual you should not be posting links to it in any language.
    Thanks Melanie. Pretty silly of me to quote what was to be deleted from the bad post.
  1. MCSP, PBP260, Win7 - is it impossible?
    By HenrikOlsson in forum General
    Last Post: - 26th January 2010, 17:08
  2. PicBasic Complier V1.42
    By andydoc in forum mel PIC BASIC
    Last Post: - 15th March 2006, 16:16
