Matching time conditions
Results 1 to 40 of 49
    Something like
    HEXRTCHour = RTCHour $ $70
    Should convert the BCD into HEX
    I think....
    malc-c's Avatar
    malc-c Guest
    Dave, thanks for the reply, but I get a syntax error with that no matter how format it, (even added a HexRTCHour var byte in the code) -
    Hmm..
    This is from one of mine to change the I2C output to HEX then display the DEC via serial.
    I2CRead DS_SDA, DS_SCL, RTC, SecReg, [sec,MINs,hr,day,date,mon,yr]
    SEC_T = sec & $70
    SEC_T = SEC_T>>4 'Tens place
    Serout2 PORTC.6, 16572,["SEC_T  ",DEC SEC_T, $d, $a]
    SEC_O = sec & $0F  'Ones place
    Serout2 PORTC.6, 16572,["SEC_O  ",DEC SEC_O, $d, $a]
    malc-c's Avatar
    malc-c Guest
    Hmm..
    Dave - I note your deliberate mistake to keep me on my toes
    SEC_T = sec & $70
    Thanks - that's compiled - will now go away and play
    That was not deliberate... dirty bifocals
    malc-c's Avatar
    malc-c Guest
    LOL -
    Dave, whist I can display the DEC value using and LCD using that code, I still can't apply it to a variable that can be worked with,
    any ideas... I simply want something like alarmhour= DEC(HEXRTCHour). It seems that whilst you can use DEC to convert and display a value or send a value via coms, you can't directly apply it.
    I was thinking not to worry about comparing to a DEC. Convert the BCD and compare to the conversion.
    If you can not get a solution I will work something up when I get back to the shop tonight.
