115200 Baud to 9600 Baud Translator
Results 1 to 17 of 17
    ScottC's Avatar
    ScottC Guest
    Question 115200 HSEROUT Not Working
    I have been messing with this for a bit and no luck. I am using a 16F873A with UART. I see a burst of data on my scope, but PC does not see it. I also know that I have to invert the signal due to the nature of HSEROUT.
    Is what I have code wise correct?
    Any Ideas? I am using a 22.1184MHz Xtal. code is below.
    Just using this as a test to see if I can get 115200 baud to work. Then I'll try to concour the above issue posted.
    DEFINE OSC 20 ' 20MHz oscillator
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 115200
    DEFINE HSER_SPBRG 2
    TRISA = 0
    TRISB = 0
    TRISC = 0
    PORTB.0 = 1
    START:
    HSerout ["12345",10]
    Pause 1000
    GoTo START
    Scott
    Ceug2005's Avatar
    Ceug2005 Guest
    try at lower speed
    this what i use , not tested uper 9600
    define OSC 20
    DEFINE HSER_TXSTA 20h ' enable the transmit register
    DEFINE HSER_BAUD 2400
    HSEROUT [dec sign0,10,dec tempc0,13]
    better to use an MAX 232 to conect at COMx
    Post
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 11
    Post
    .... and mode 97 should give 9600 baud with SEROUT2. However, you would probably do yourself a favour by switching to a 20MHz crystal since PBP likes that better, all timings will be correct. 115200 baud works quite well with 20MHz and HSEROUT.
    DEFINE HSER_SPBRG 10
    .... will give you 115200 with 20MHz.
    ScottC's Avatar
    ScottC Guest
    Thumbs up 115200 Baud Working!
    Well, at last I have success! Thanks to all who pitched in to make this happen. I adjusted the values in the define statements as suggested.
    I am still using 22.1184 XTAL. Here is the test code below.
    Thanks again.......
    Scott
    DEFINE OSC 20 ' 20MHz oscillator (22.1184MHz)
    TRISA = 0
    TRISB = 0
    TRISC = 0
    START:
    HSerout ["HELLO"]
    Pause 500
    GoTo START
    ScottC's Avatar
    ScottC Guest
    Question 9600 Baud to 115200
    Well, interesting. Now I am trying to take in the character at 9600 and resend at 115200. When I do this code below, my results are not what I want!
    For example when I send the number 1, I receive an "a", send 2, I get an "f"
    3 a "g", ect till I send 6, the sequence jumps to "n", "o".. Really strange.
    I don't know if it is a timing issue or not???? Puzzled.
    It was mentioned above that I could change the baud rate on the fly, How is that done? Could the issue be I have different baud rates on different pins, seems it should not matter. I'm lost..
    ScottC
    DEFINE HSER_BAUD 115200 '115200 Baud Out
    DEFINE DEBUGIN_REG PORTB ' 9600,8,N,1 Serial In
    DEFINE DEBUGIN_BIT 7
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUGIN_MODE 1
    B7 VAR BYTE
    TRISA = 0
    TRISB = %00000001
    TRISC = 0
    '********************************* READ SERIAL PORT
    loop: While PORTB.7 = 1 'Wait for start bit
    Wend
    DebugIn [B7] ' B0 = input character
    Pause 500
    print: HSerout [B7]
    GoTo loop ' Forever
    Are you're still using the 22.1184MHz crystal?
    DEBUGIN bit timing is calculated for 20MHz with DEFINE OSC 20.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Last Post: - 8th March 2010, 21:58
  2. Replies: 14
    Last Post: - 20th March 2008, 14:54
  3. pic18f4520 baud rate change to 115200
    By caltex88 in forum mel PIC BASIC Pro
    Last Post: - 30th September 2007, 09:41
  4. Auto Baud Rate Detection
    By mytekcontrols in forum Serial
    Last Post: - 31st October 2005, 03:17
  5. Baud Rate and Timing Calculator
    By picnaut in forum General
    Last Post: - 23rd January 2004, 17:48
