Well the PIC's working with those settings - I went back to basics and wrote the following simple basic "hello world" type code.
This displays "Number = " and counts from 1 to 10 on the LCDCode:ASM ; 18F2550/4550, 20mhz crystal ; __CONFIG CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L ; __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H __CONFIG _CONFIG2L, _PWRT_ON_2L __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H __CONFIG _CONFIG3H, _PBADEN_OFF_3H __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L ENDASM DEFINE OSC 48 clear ;----[LCD definitions]------------------------------------------------------ DEFINE LCD_DREG PORTB ' LCD Data port DEFINE LCD_DBIT 0 ' starting Data bit (0 or 4) DEFINE LCD_EREG PORTB ' LCD Enable port DEFINE LCD_EBIT 5 ' Enable bit (on EasyPIC 5 LCD) DEFINE LCD_RSREG PORTB ' LCD Register Select port DEFINE LCD_RSBIT 4 ' Register Select bit (on EasyPIC 5 LCD) DEFINE LCD_BITS 4 ' LCD bus size (4 or 8 bits) DEFINE LCD_LINES 4 ' number of lines on LCD DEFINE LCD_COMMANDUS 2000 ' Command delay time in us DEFINE LCD_DATAUS 50 ' Data delay time in us ;--------------------------------------------------------------------------- counter var byte for counter = 1 to 10 LCDOut $FE,2,"Number = ",dec counter pause 10 next
I've looked at the datasheet, but can't see anything obvious other than making the correct pins on Port C input or outputs (something I would of thought would of ported over from the code)
Any suggestions
