Stuttering Servo
Results 1 to 9 of 9
    Default Stuttering Servo
    I am testing a DT Instant interrupt routine which is supposed to set the length of time that two servos are on or off. Everything works OK except the servos runs very rough. The average position of the servos is correct, but the twitching movement is excessive, making it unuseable. The timing is based on the Elapsed Timer1 Program, from routines found on this Forum. For comparison purposes I have another routine that does not use interrupts, but relies on cycle counting. With this program the servos are smooth and quiet. The cycle counting demo follows here:
    'device is PIC 16F684
    'set registers
            OPTION_REG.7 = 0     'enable porta pullups
            CMCON0 = 7           'comparators off
            ANSEL = 0            'porta pins all digital
            TRISA = %111111      'set porta pins as input
            TRISC = %001101      'set portc pins 0,2,3 as input, all others output
            OSCCON = %1110000    'set internal osc. at 8 mhz, wait for stable freq.
            OSCTUNE = 0          'internal osc. running at factory calibration
            DEFINE OSC 8         '8 Mhz oscillator
            while OSCCON.2 = 0   'wait for osc.to be stable
            wend
    'declare variables
            i       var word         'couting variable
            led     var portc.3      'led output on portc.3
            dummy   var byte         'variable needed to end porta mismatch
            throttlepos var word     'servo1 pulse width in .01 seconds
            servopos    var word     'servo2 pulse width
            pulsecnt    var byte
    start:
            low led      'flash red LED for 0.5 sec to show circuit is functioning
            high led
            pause 2000   'delay timer start 2 seconds
            portc.1 = 0               'turn off servo
            portc.4 = 0               'initialize servo pulse low
            portc.5 = 0               'initialize throttle pulse low
            throttlepos = 400         '2*(200)  pulse width adjusted for 8 mhz osc
            servopos = 400            '2*(200)  pulse width adjusted for 8 mhz osc
            low Led                    'turn on led
            portc.1 = 1                'turn on servos
            for i = 1 to 500           'run servo for 10 seconds (500 cycles)
            pulsout portc.5,throttlepos
            pulsout portc.4,servopos
            pause 16
            next
            high Led                  'turn off led
            throttlepos = 200         '2*(100)  pulse width adjusted for 8 mhz osc
            for i = 1 to 75           'run servos for 1.5 seconds (75 cycles}
            pause 16
            next
            low Led                   ' turn on led
            for i = 1 to 750          'run servos for 15 seconds 750 cycles)
            pauseus 16100
            next
            high led              'turn off led
    DT:     high portc.3          'turn off led
            servopos = 200        'DT release position 2*(100)
            pulsecnt = 75         'hold for 1.5 second
            gosub pulse           'this section uses a subroutine to run the servo
            servopos = 400        'home  position
            pulsecnt = 50         'hold for 1 second
            gosub pulse           'return to home position
            goto halt
    'subroutine pulse runs the servo
    pulse:  portc.4 = 0                'initialize servo pulse low
            for i = 1 to pulsecnt
              pause 18
            next
    halt:
    The demo interrupt program is follows here. Two interrupts are used in this case, but it makes no difference; the servos runs rough even when the interrupt on change is taken out. The twitching is still there even if only one servo is used. Any ideas on why the rough running?
    'set registers
            wend
    'declare variables
            i       var byte
            MTtime  var word         'target motor runtime in tenths of seconds
            BKtime  var word         'target brake time in tenths of seconds
            DTtime  var word         'target DT time in tenths of seconds
            servopos    var word
            pulsecnt    var byte
    start:
            high led
    INCLUDE "DT_INTS-14 for F684.bas" 'Base interrupt with wsave selected for 16F684
    INCLUDE "ReEnterPBP.bas"          'Using PBP interrupts
    INCLUDE "Elapsed_INT_RI2.bas" 'Elasped timer counting seconds and tenths seconds
    INT_LIST  macro     ; IntSource,        Label,  Type, ResetFlag?
            INT_Handler   RAC_INT,   _RDT,          PBP,  yes
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
    goto overint
    '-------Interrupt Handler for RDT------------
    RDT:
       high led                      'turn led off
       dummy = porta                 'needed to end mismatch for porta
       IOCA.4 = 0                    'disable porta.4 interrupt
    @ INT_RETURN
    overint:
        dummy = porta             ' initialize dummy variable
        IOCA.4 = 1                ' enable porta pin 4 for interrupt on change
        MTtime = 100              ' 10.0 second motor run time
        BKtime = 15               ' 1.5 second brake time
        DTtime = 150              ' 15 second glide time
        gosub ResetTime           ' Reset Time to  0d-00:00:00.00
        gosub StartTimer          ' Start the Elapsed Timer
    @    INT_ENABLE  RAC_INT       ; Enable PortA Change Interrupt
    @    INT_ENABLE  TMR1_INT      ; Enable Timer 1 Interrupts
                pause 17
            if IOCA.4 = 0 then
            goto newtime1              'jump to end-time on interrupt
            if sum => MTtime then      'stop when target end time is reached
            goto newtime1
    goto main                      'loop until endtime is reached
    newtime1:
            gosub StopTimer           ' Stop Timer1
            throttlepos = 200         ' 2*(100)
    brake:
                pause 17
            if IOCA.4 = 0 then
            goto newtime2              'jump to end-time on interrupt
            if sum => BKtime then      'stop if elapsed time = target end-time
            low led                    'turn on led
            goto newtime2
    goto brake
    newtime2:
            gosub StopTimer
            IOCA.4 = 1                ' re-enable porta pin 4 for interrupt on change
            portc.5 = 0               ' initialize throttle pulse low
            portc.4 = 0               ' initialize servo pulse low
    glide:
                pause 17
            if IOCA.4 = 0 then
            goto DT                   'jump to end-time on interrupt
            if sum => DTtime then     'stop if elapsed time = target end-time
            goto DT
    goto glide
    @    INT_DISABLE  RAC_INT       ; Disable PortA Change Interrupt
    @    INT_DISABLE  TMR1_INT      ; Disable Timer 1 Interrupts
            gosub pulse
            goto halt
              pause 18
            next
    halt:
    What does the pulse train look like on an oscilloscope?
    Good suggestion, but alas, I do not have a scope.
    Could be anything from a weak power supply to weak code
    Try a simple code to run the servos without the "fancy" stuff to help narrow it down.
    Lightbulb
    @ first look the problem comes because PULSOUT commands might not be " interrupted " ... and maybe also because time between two pulse must be kept, say, between 15 and 30 ms ...
    Hello all,
    I have tried a minimalist aproach. With only one servo, holding at one position, and no interrupt on change ... just the timer1 interrupt keeping track of elapsed time. The one servo is still very twitchy to the point of not being useable.
    BTW, the accuracy of elapsed time is very good when checked with a stopwatch..
    Quote Originally Posted by Dick Ivers View Post
    Not a problem! Capture the signal train on your sound card, and see it thru' a sound editor like Audacity as described on Dave Houston's website. Or alternately, for these frequencies a sound card based scope like the one at http://www.zeitnitz.de/Christian/scope_en (my favourite) would work fine. WYSIWYG!
    Just remember to scale down the logic levels by 10:1 or more.
    Anand
