Further exploits of my trials with an 18F4580 has resulted in getting the two programs independantly migrated across and working. However when I merged the two together I was getting problems with the PID routines. I found that there was a conflict with the two codes as the both use the data comand to write to the EEprom area.
PID code uses this code
;----[EEPROM Data]----------------------------------------------------------
DATA @0,0
EE_spMode1        DATA 0                        ' 0=Manual mode, temp is set by Pot.
EE_SetPoint1      DATA WORD 260                 ' 26.0 deg. after programming if not in manual mode
EE_pid_Kp1        DATA WORD $0700               ' PID constants
EE_pid_Ki1        DATA WORD $0080
EE_pid_Kd1        DATA WORD $0200
EE_pid_Ti1        DATA 8                        ' Update I-term every 8th call to PID
EE_pid_I_Clamp1   DATA 125                      ' Clamp I-term to max ±100
EE_pid_Out_Clamp1 DATA WORD 255                 ' Clamp the final output to 255
EE_CH1PWR         DATA 1                        ' this needs to be set to 1 to enable heater channel
;---(PID channel 2 defaults)------
EE_spMode2        DATA 0                        ' 0=Manual mode, temp is set by Pot.
EE_SetPoint2      DATA WORD 260
EE_pid_Kp2        DATA WORD $0700               ' PID constants
EE_pid_Ki2        DATA WORD $0080
EE_pid_Kd2        DATA WORD $0200
EE_pid_Ti2        DATA 8                        ' Update I-term every 8th call to PID
EE_pid_I_Clamp2   DATA 125                      ' Clamp I-term to max ±100
EE_pid_Out_Clamp2 DATA WORD 255                 ' Clamp the final output to 255
EE_CH2PWR         DATA 1                        ' this needs to be set to 1 to enable heater channel
;---(PID channel 3 defaults)------
EE_spMode3        DATA 0                        ' 0=Manual mode, temp is set by Pot.
EE_SetPoint3      DATA WORD 260
EE_pid_Kp3        DATA WORD $0700               ' PID constants
EE_pid_Ki3        DATA WORD $0080
EE_pid_Kd3        DATA WORD $0200
EE_pid_Ti3        DATA 8                        ' Update I-term every 8th call to PID
EE_pid_I_Clamp3   DATA 125                      ' Clamp I-term to max ±100
EE_pid_Out_Clamp3 DATA WORD 255                 ' Clamp the final output to 255
EE_CH3PWR         DATA 1                        ' this needs to be set to 1 to enable heater channel
;---(PID channel 4 defaults)------
EE_spMode4        DATA 0                        ' 0=Manual mode, temp is set by Pot.
EE_SetPoint4      DATA WORD 260                 ' 26.0 deg. after programming
EE_pid_Kp4        DATA WORD $0700               ' PID constants
EE_pid_Ki4        DATA WORD $0080
EE_pid_Kd4        DATA WORD $0125
EE_pid_Ti4        DATA 8                        ' Update I-term every 8th call to PID
EE_pid_I_Clamp4   DATA 125                      ' Clamp I-term to max ±100
EE_pid_Out_Clamp4 DATA WORD 255                 ' Clamp the final output to 255
EE_CH4PWR         DATA 1                        ' this needs to be set to 1 to enable heater channel
The RTC code has this code
'EEPROM Locations
	Data @0,74,97,110,70,101,98,77,97,114,65,112,114
		' Jan Feb Mar Apr
	Data 77,97,121,74,117,110,74,117,108,65,117,103
		' May Jun Jul Aug
	Data 83,101,112,79,99,116,78,111,118,68,101,99
		' Sep Oct Nov Dec
	Data 84,117,101,87,101,100,84,104,117,70,114,105
		' Tue Wed Thu Fri
	Data 83,97,116,83,117,110,77,111,110
		' Sat Sun Mon
If I add just the latter to the PID code it causes the PID routine to incorrectly function. I've looked at the datasheet but my inexperience makes it as clear as mud.
Is there a way of using the two sets of data, but keeping them at separate memory locations so they don't clash
