Array -- something wrong?
Results 1 to 24 of 24
    Default Array -- something wrong?
    For the life of me, I can't figure out what is wrong with this code. This is just the start of a program where I check all the bytes in the serial port (DATAIN) --
    if the total = 0 then it just loops and an LED is off.
    If any of the bytes contain data (a 1 or greater) then the LED is on. Then, eventually on to do other stuff.
    Maybe it's the way I set up the array as I've never used one in picbasic before.
    The pause is in there so I can see the LED. Thanks for any help.
    DATAIN VAR BYTE[13]
    ADDUP VAR BYTE
    TOTAL VAR BYTE
    QUAL1 VAR BYTE
    QUAL2 VAR BYTE
    DATAIN= 0
    TOTAL = 0
    ADDUP = 0
    QUAL1 = 170
    QUAL2 = 255
    START:
    SerIn PORTA.0,N1200,[QUAL1,QUAL2],DATAIN
    FOR TOTAL = 1 TO 13
    ADDUP = ADDUP + DATAIN[TOTAL]
    NEXT TOTAL
    IF ADDUP = 0 THEN
    LOW PORTA.1 'DATA RECEIVED LED OFF
    GOTO START
    IF ADDUP >= 1 THEN
    HIGH PORTA.1 'DATA RECEIVED LED ON
    PAUSE 3000
    ADDUP = 0
    TOTAL = 0
    DATAIN = 0
    GOTO START
    Feb 2003
    For a 13 element array it should be 0 to 12
    Keith
    www.diyha.co.uk
    www.kat5.tv
    right after I posted I went to lay down -- and realized I put a one in there for some odd reason.
    thanks.
    oh well -- thought that was it myself but still no go -- yet I know my data is there on the serial port.
    on the PC end (using VBnet), I have my 2 qualifiers 170 and 255 then 13 bytes being sent. everything fine N1200, port etc.
    changed the PIC to --
    DATAIN[13]
    and (FOR 1 TO 12).
    still nothing?
    Feb 2003
    What chip are you using ?
    does it have analogue ports ?
    Keith
    www.diyha.co.uk
    www.kat5.tv
    16c72 (old timer)
    but I did ADCON1 = 7
    that changes porta to digital, right?
