Well not fails, but seem to behave odd...
if i create a simple for-next with a byte variable and out it the channel 1 or 2, with led's connected, the leds raise in brightness 3 (yes three) times for the loop!
I am using USB with DT interrupts, and ADC on ra0/ra1, idea was the adc value of ra0/1 woul;d pwm the outputs on channel 0/1
Is there any defines I should be looking at etc or anything else i can post to help?
18f2550, at 4mhz, pll div 1 OSC 48 etc.
Code:DEFINE HSER_RCSTA 90h DEFINE HSER_TXSTA 20h ; 24 is giving error DEFINE HSER_BAUD 9600 ' DEFINE HSER_SPBRG 25 ' let picbasic set it from the baud def above DEFINE HSER_EVEN 1 DEFINE CHAR_PACING 1000 ' slow things a little DEFINE HSER_CLOERR 1 ' automatic clear overrun error DEFINE ADC_CLOCK 1 DEFINE ADC_BITS 8 DEFINE ADC_SAMPLEUS 10 ADCON1 = %10000011 ; not sure lol CMCON = 7 ; Disable Comparators INTCON2.7 = 0 ; should enable portb pullups. for tempx=0 to 255 HPWM 0,tempx,1000 hpwm 1,255-tempx,1000 portb=tempx pause 125 next
maximu brightness is at 87 and 174, not 255....
any ideas what could be causing this looping?
edit: user error, time to RTFM...
freq too low for clock speed...
