serin/hserin fail when i break the standard...
Results 1 to 18 of 18
    Try adding this after the HSERIN
    RCSTA.4 = 0 : RCSTA.4 = 1
    actually i think i have found an answer, may not be right one, gonna do some testing, but will try that too.
    one thing i can say, it works with 3v serial, infact i'm at about 2.8v, and its stable.
    DEFINE HSER_SPBRG 225 ' 9600 Baud @ 48MHz, 0,0%
    SPBRGH = 4
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
    the above lines cured all my serial in problems.
    I think the last 3 were the important bits, but now when the buffer fills it just ignores extra chars etc, no more ''going deaf''
    using them with
            __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
            __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
            __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_ON_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    And a 20mhz crystal gives trouble free operation to the phone/module, and no issue with the 3v signals.
    I had to remove the resistor/led combination from the rx pin, it was loading the module a little and dropping its voltage down too low to be seen by the pic, but with a direct connection transfers have been error free. (measured on voltmeter as 2.8v, 2.75 and bits go missing...)
    Thanks to everyone for there input and ideas, I dont know where I would have been without you all this last few weeks!
