serin/hserin fail when i break the standard...
Results 1 to 18 of 18
    You can connect a PIC directly to RS232 (usually though a Resistor). The problem is YES it is inverted. For all intents and purposes a HIGH (say +12v) is ZERO, and a low (-12v) is a ONE. You can extend this by simply saying, that if it isn't a HIGH, then it's got to be a LOW. So again, if the signal is above 5v (ie it has swung to +12) the PIC will tollerate that (our Resistor helps) and Register a PIC LOGIC 1 (RS232=Zero), and if the swing goes to -12v, again our PIC doesn't care once it falls below 0v, because it registers a Logic 0 (RS232=1). So here +12/-12v is fine, just a Resistor and you're good to go.
    If you use SOFTWARE ASYNC like SERIN, you do it simply by specifying that it is inverted and SERIN does the rest.
    But if you use the HARDWARE USART, and HSERIN, there is no automatic way of inverting, so you need something like a MAX232 (or transistor or whatever) to HARDWARE INVERT the signal before you feed it into the PICs USART.
    In this thread a 0v to +3v swing doesn't do it for the PIC running at 5v. 3v may or may not be sufficient to score a Logic 1 in the PIC. It's unreliable, and it looks like f-lez has a problem. But here is where the Comparator scores on TWO COUNTS. (1) it can RESTORE your 0-5v signal (from an input as little as only a few millivolts), and (2) it has the ability to INVERT the output for you (real convenient when you need to INVERT a signal for the USART).
    The COMPARATOR won't give you +12/-12v for OUTPUT purposes, but it will take whatever cr*p you want to throw at it and give you clean Data with a nice solid 0-Vdd swing for the PIC to logically process thereafter. So treat the COMPARATOR as a LOGIC LEVEL SHIFTER, a DATA RESTORER, an INVERTOR, an AMPLIFYER, a NOISE FILTER... what more could you ask for? And you got it FREE all BUILT-IN to your PIC!
    Except for the PIC18 chips by using RXDTP and TXCKP to invert your hardware UART.
    See
    http://www.picbasic.co.uk/forum/show...ight=inverting
    By the way Melanie, your comparator solution is very slick! Thanks, I have a 3v to 5 volt issue I think I will use it on.
    Walter
    A lot of people miss this, but if you have an external 3V device, and it's not working on a
    certain pin, make sure you're not using a pin with a Schmitt Trigger input buffer.
    A pin with a TTL input buffer should work fine with the 3V input if VDD >= 4.5V and <= 5.5V.
    A Schmitt Trigger input needs ~0.8 * VDD to meet the input logic 1 threshold.
    The comparator trick is cool too, but you might fix it by just switching to a TTL input.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Ha ha some good ideas i like the comparator hack, i may have to try that as a test to see just if it is a level issue, as i would like to keep those pins free for the pwm.
    Pic is 18f2550 so it has them, and I am running it at 5v, the phone/dsm module is 3v but 5v wont harm it.
    I have tried input on both port b and C and tried with and without pullups enabled.
    I will try the HW uart again with inverted as i am unsure of the stream polarity.
    Heres the start of my code as a test etc and to show the configs I have
    ;DEFINE RESET_ORG 800h
    ;DEFINE INTERRUPT_ORG 808h
    define OSC 48
    ;dEFINE LOADER_USED 1
     ; first four lines to fix broken pbp246
    UIR  VAR BYTE EXT
    UIE  VAR BYTE EXT
    UEIE VAR BYTE EXT
    UEIR VAR BYTE EXT
    INCLUDE "MODEDEFS.BAS"
    include "c:\dtusbsvc.pbp"  ' would not know what to do without them !
    ' setup serial hardware comms
    DEFINE HSER_RCSTA	90h
    DEFINE HSER_TXSTA	20h    ; try 24 if errors
    DEFINE HSER_BAUD	9600
    DEFINE HSER_EVEN	1
    DEFINE CHAR_PACING 1000   ' slow things a little
    DEFINE HSER_CLOERR  1 ' automatic clear overrun error
    ' DEFINE HSER_SPBRG	25  ' let picbasic set it from the baud def above
    DEFINE ADC_CLOCK 1
    DEFINE ADC_BITS 8
    DEFINE ADC_SAMPLEUS 10
    ADCON1 = %10000011 ; not sure lol
    CMCON = 7                 ' Disable Comparators
    INTCON2.7 = 0 ; should enable portb pullups.
    TRISA = 3      ;  configure AN0 an1 as an input
    trisb = 255
    trisc=255
    tempx     var byte ; temps..
    tempy     var byte ; temps..
    loop:
    hserout ["atd123",13,10]
    for tempx=1 to 2 ; look for 2 chars from it for ''ok''
    serin portb.7,n9600,10,tlable,tempy
    tlable:
    ; gosub send tempy to usb to pc terminal
    next
    goto loop
    What do you get with: serin portb.7,T9600,tempx,tempy
    -Bruce
    tech at rentron.com
    OK its gone from bad to worse.....
    On the downside my internet is down so I only have this mobile phone, but I have now dusted off my old dual trace scope...
    What it Ias shown me is I seem to have a timing error...
    I have changed from a 4 to a 20mhz crystal go case It was off freq.
    I can't use the scope to check timing accuracy its very old and calibrated.
    I can't cut and paste my configs now!
    As a rule of thumb, if I use the right settings to clock the pic at 20mhz I would be right with pll/5 to be right for usb.
    CAn I get a good 9600 set that way?
    How many chars can be transferred in say 10 secs?
    The scope shows returning data but it looks like the phone/modem. IS at a different speed
    This is what you need with a 4MHz external
    DEFINE OSC 48
    @ __CONFIG   _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @ __CONFIG   _CONFIG1H, _FOSC_HSPLL_HS_1H
    @ __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
    @ __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
    @ __CONFIG    _CONFIG4L, _LVP_OFF_4L & _ICPRT_OFF_4L &_XINST_OFF_4L
