You just can't not read the datasheets. You will get nowhere.
In the data sheet: http://ww1.microchip.com/downloads/e...Doc/30487c.pdf
It says:"The CCP module’s input/output pin (CCP1) can beconfigured as RB0 or RB3. This selection is set in bit 12 (CCPMX) of the Configuration Word".
So we read the whole document so that we have a small idea where to find this register, or, we do a search in the document for this register.
On page 130 we find register 15-1. Here we find bit 12 - the CCPMX bit.
No escaping it - for real - truths - RTFDS.
You were also told by Aratti about minimum frequencies: You still set it for what you wanted; not what it can do. In the table regarding 14-bit core it says @4MHz the minimum frequency is 245Hz. 245 is more than 100.
RTFM...
