Interrupt won't execute.
Results 1 to 24 of 24
    Have a look to your PMs ... and enjoy
    @ Darrel : Do not look at it ... you won't like at all ...
    Talking
    Here it is for Everyone ...
    a running version with a 16F877a and EasyPic 5 .
    still something to debug with HSEROUT, probably a timing issue ...
    '*  Name    : AdcServo2 : the ultimate vibrator ...             *
    '*  Notice  : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 01/10/2008                                        *
    '*  Process.: 16F877a / EasyPic5                                *
    ' Config
     @ device HS_OSC , WDT_ON , PWRT_ON , BOD_ON , LVP_OFF , protect_OFF
    'Defines
    DEFINE OSC 8
    DEFINE INTHAND _MAINLOOP
    DEFINE HSER_TXSTA 20h       'SET THE TRANSMIT REGISTER TO TRANSMITTER ENABLED
    DEFINE HSER_BAUD 9600       'SET BAUD RATE
                                'DEFINE ADCIN PARAMETERS
    DEFINE ADC_BITS	10          'SET NUMBER OF BITS IN RESULT
    DEFINE ADC_CLOCK 3          'SET CLOCK SOURCE (3=RC)
    DEFINE ADC_SAMPLEUS 50	    'SET SAMPLEING TIME IN uS
    DEFINE LCD_DREG PORTB               ' I/O port where LCD is connected
    DEFINE LCD_DBIT 0					' 0, 1, 2, 3
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4                  ' Register select pin
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5                   ' Enable pin
    DEFINE LCD_BITS 4                   ' 4-bit data bus
    DEFINE LCD_LINES 2                  ' LCD has 2 character lines
    ' Comparator Config
    CMCON       = %00000111
    ' Adc Config
     ADCON0     = %11000001     'SET PORTA ANALOGUE AND RIGHT JUSTIFY THE RESULT
     ADCON1     = %10001110
    ' TMR1 Config : Preset = 45543  - Prescaler 1
    T1CON       = %00000000          'SETS THE TIMER1 VALUES - PRESCALER = 1
    ' Interupts config
     INTCON     = %11000000         ' GIE + PIE
     PIE1       = %00000001         ' TMR1IE
     PIR1       = 0
     PIE2       = 0
     PIR2       = 0
    'Variables
    wsave       var byte $20   system   ' just to avoid a compilator error ...
    wsave1      var byte $a0   system
    wsave2      var byte $120  system
    wsave3      var byte $1a0  system
    ssave       var byte Bank0 system
    psave       var byte Bank0 system
    POSITION    VAR WORD        'POSITION OF SERVO1 1250 - 2500
    TEMP        var word
    PLOW        var word        'low part of the servo signal
    COUNTER     var word        'Timeout counter
    PRESET      var word
    Delay       var BYTE
    RUN         VAR BIT         'IS THE PROGRAM RUNNING
    'Aliases
    GIE         var INTCON.7
    PEIE        var INTCON.6
    TMR1IE      var PIE1.0
    TMR1IF      var PIR1.0
    TMR1ON      var T1CON.0
    ' Variable presets
    RUN         = 0                     'TEMPORARY VARIABLE FOR SERVO RUNNING
    POSition    = 150                   ' Servo @ RestPositon.
    counter     = 0                     ' timeout counter
    PRESET      = 25555
    TMR1H       = Preset.Highbyte       ' Must be initialized ...
    TMR1L       = Preset.Lowbyte
    ' Constants
    SELECTOR    CON 0                   'Assign selector ADC Input to AN0
    ' I/Os
    SERVO1      var PORTC.0             'OUTPUT PIN FOR SERVO1
    STARTSTOP   VAR PORTA.4             'INPUT PIN FOR PUSHBUTTON
    PORTA = %00010111
    PORTB = 0
    PORTC = 0
    PORTD = 0
    PORTE = 0
    TRISA = %00000011
    TRISB = 0
    TRISC = 0
    TRISD = 0
    TRISE = 0
    Pause 500
    LCDOUT $FE, 1        ' Clear display, cursor off
    MAINLOOP: ' Here we start a cycle ...
    TMR1on      = 0                     ' Reload the timer ...
    TMR1H       = PRESET.Highbyte
    TMR1L       = PRESET.Lowbyte
    TMR1IF      = 0
    TMR1ON      = 1                     ' Restart the timer
    GIE         = 1                     ' Interrupts authorized
    IF run THEN                         ' Run Button has to be pushed for first move
    FINDPROGRAM:                        'SELECTS BETWEEN SEVERAL TYPES OF MOTION
        ADCIN Selector , TEMP          'READ CHANNEL 10 TO TEMP
        SELECT CASE TEMP
        	Case is <  250
        	 	POSITION = 125
            Case is <= 366
         		POSITION = 150
        	Case is <= 583
        	 	POSITION = 175
        	Case is <= 783
        		POSITION = 200
        	Case is <= 1000
         		POSITION = 225
        	Case is >  1000
         		POSITION = 250
         End Select
        low servo1
        Pulsout Servo1, position
        PLOW = 20000-POSITION
        IF COUNTER.5 OR ! COUNTER THEN
            'HSEROUT ["HIGH =" , DEC POSITION, " LOW =", DEC PLOW, 10,10,13]
            LCDOUT $FE,2 ,"Position = ",dec position,"    ", $FE,$C0,"TEMP = ", dec TEMP,"     "
        Endif
            'HSEROUT ["Waiting for RUN", 10,10,13,"HIGH =" , DEC POSITION, " LOW =", DEC PLOW, 10,10,13]
            LCDOUT $FE,2 ,"Waiting for RUN", $FE,$C0,"Position = ", dec position
    TESTINPUTS:
    Delay = 0
    Button Startstop,1,255,0,Delay,0,jump    ' Button active LOW !!!
    IF RUN THEN COUNTER = counter + 1
    IF counter => 60000 then counter = 0 :goto jump
    stop                                     ' Stop here and wait for interrupt
                                                ' to launch a new cycle
    JUMP:
    WHILE STARTSTOP = 0 : wend
    RUN = ~run
    enjoy ...
