Interrupt won't execute.
Results 1 to 24 of 24
    Thumbs down
    Hi, Jumper
    DT Basic Interrupts are wayyy too slow, here ... and overall their execution time is not predictable for timing corrections ...
    so, no joy nor !
    You do have to deal with ASM ... or write the program in pure PBP, without any interrupts ...
    PS: and do not forget DT Bas ints consume a lot of RAM ...
    @ BB
    Does this mean there's another way of doing this without interrupts?
    Bear in mind that I need to expand this to running two servos at once.
    I alredy built a 4 channels fail-safe in pure PBP ... 4 Channels to read and 4 channels to output ... so, your project looks quite doable.
    Writing a neat timechart ... of course.
    Mar 2010
    Unhappy One last question.
    alright Ace, I give in, you've got me in dispair with this project, I'll look for a totally different way.
    Is this something you've released that I can learn from or even adapt?
    If I can't see the code, can you give me some hints about the way forward?
    I don't mind all the time charts in the world, but what's it for?
    I'll stop bothering you now, time for bed.
    Either way, thanks for the help, it's good to know when the idea you've got is impossible, that way you can move on; even if it is disheartening. Sniff...
    I'll check out DT's interrupts anyway - always learning.
    Wink
    Ok BB
    First of all ...
    explain with clear words what your device has to do :
    from which inputs (w/ details ) to which outputs ( w/details ) ...
    50% of the work is here ...
    PS: and stop thinking " C " ... you must think " Basic " now ! ( ROFL)
    Too Slow???
    For a Servo??? Get real.
    I've run 16 servo's simultaneously with DT_INTS.
    Timing not predictable??? What???
    It's extremely predictable. What are you talking about?
    oooo, ~50 bytes to have super easy interrupts, yeah too much RAM.
    Quote Originally Posted by bison_bloke
    Don't listen to Alain.
    He's just being obstinate.
    Mar 2010
    Default Ok, let's see if we can make something of this mess...
    Does this mean there's code out there that I can directly adapt?
    Where would I find this?
    I have two inputs: start/stop button and a 'selector switch' which I already have working with that if statement you see above.
    I have three outputs: two servos that I need to 'bounce' independently of each other. I need them to simulate the somewhat random movements that a passenger in a car would experience whilst driving. The third input is for vibration, this is just an unbalanced DC motor - np.
    I also want to run a countdown timer so that it gets turned of after 20mins.
    So now that my project is exactly half done, which way do I head?
    Quote Originally Posted by bison_bloke View Post
    Well, that program is extensive ... each channel has it's own Center Trim, Gain and 10-bit positions, with stored programmed movements.
    Never released it. Because I'd have to support it.
    But since you don't seem to mind ON INTERRUPT ... there's a sample at meLabs for the LAB-X1 board.
    It drives 2 servos using interrupts.
    Has buttons, an LCD ... sounds just like what you wanted.
    servosx.bas
    http://melabs.com/resources/samples.htm
    Question
    Hi, BB
    Just missing : is both servos position given by a unique " selector pot " ( 6 positions , if I have correctly understood ) , so both servos receive same driving pulse ???
    For the Heading ...
    I'd propose you a " system clock " @ 50 Hz ... with a timer interrupt ( very, very simple kind of interrupt ). And as 20 mins = 60000 " ticks " @ 50 Hz ... it's done
    If you think to it, tasks are done in a linear way and the whole sequence is repeated @ 50 Hz ...
    so, just let me an hour to open the '690 Datasheet ( never worked with this chip to the day ) ...
    Mar 2010
    Both servos will run on different signals. There will be no pots involved.
    The user selects a 'program' from the selector switch, hit's start, and a predefined program controls everything from there. The servos will almost always be in different positions to each other.
    Have a look to your PMs ... and enjoy
    @ Darrel : Do not look at it ... you won't like at all ...
    Talking
    Here it is for Everyone ...
    a running version with a 16F877a and EasyPic 5 .
    still something to debug with HSEROUT, probably a timing issue ...
    '*  Name    : AdcServo2 : the ultimate vibrator ...             *
    '*  Notice  : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 01/10/2008                                        *
    '*  Process.: 16F877a / EasyPic5                                *
    ' Config
     @ device HS_OSC , WDT_ON , PWRT_ON , BOD_ON , LVP_OFF , protect_OFF
    'Defines
    DEFINE OSC 8
    DEFINE INTHAND _MAINLOOP
    DEFINE HSER_TXSTA 20h       'SET THE TRANSMIT REGISTER TO TRANSMITTER ENABLED
    DEFINE HSER_BAUD 9600       'SET BAUD RATE
                                'DEFINE ADCIN PARAMETERS
    DEFINE ADC_BITS	10          'SET NUMBER OF BITS IN RESULT
    DEFINE ADC_CLOCK 3          'SET CLOCK SOURCE (3=RC)
    DEFINE ADC_SAMPLEUS 50	    'SET SAMPLEING TIME IN uS
    DEFINE LCD_DREG PORTB               ' I/O port where LCD is connected
    DEFINE LCD_DBIT 0					' 0, 1, 2, 3
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4                  ' Register select pin
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5                   ' Enable pin
    DEFINE LCD_BITS 4                   ' 4-bit data bus
    DEFINE LCD_LINES 2                  ' LCD has 2 character lines
    ' Comparator Config
    CMCON       = %00000111
    ' Adc Config
     ADCON0     = %11000001     'SET PORTA ANALOGUE AND RIGHT JUSTIFY THE RESULT
     ADCON1     = %10001110
    ' TMR1 Config : Preset = 45543  - Prescaler 1
    T1CON       = %00000000          'SETS THE TIMER1 VALUES - PRESCALER = 1
    ' Interupts config
     INTCON     = %11000000         ' GIE + PIE
     PIE1       = %00000001         ' TMR1IE
     PIR1       = 0
     PIE2       = 0
     PIR2       = 0
    'Variables
    wsave       var byte $20   system   ' just to avoid a compilator error ...
    wsave1      var byte $a0   system
    wsave2      var byte $120  system
    wsave3      var byte $1a0  system
    ssave       var byte Bank0 system
    psave       var byte Bank0 system
    POSITION    VAR WORD        'POSITION OF SERVO1 1250 - 2500
    TEMP        var word
    PLOW        var word        'low part of the servo signal
    COUNTER     var word        'Timeout counter
    PRESET      var word
    Delay       var BYTE
    RUN         VAR BIT         'IS THE PROGRAM RUNNING
    'Aliases
    GIE         var INTCON.7
    PEIE        var INTCON.6
    TMR1IE      var PIE1.0
    TMR1IF      var PIR1.0
    TMR1ON      var T1CON.0
    ' Variable presets
    RUN         = 0                     'TEMPORARY VARIABLE FOR SERVO RUNNING
    POSition    = 150                   ' Servo @ RestPositon.
    counter     = 0                     ' timeout counter
    PRESET      = 25555
    TMR1H       = Preset.Highbyte       ' Must be initialized ...
    TMR1L       = Preset.Lowbyte
    ' Constants
    SELECTOR    CON 0                   'Assign selector ADC Input to AN0
    ' I/Os
    SERVO1      var PORTC.0             'OUTPUT PIN FOR SERVO1
    STARTSTOP   VAR PORTA.4             'INPUT PIN FOR PUSHBUTTON
    PORTA = %00010111
    PORTB = 0
    PORTC = 0
    PORTD = 0
    PORTE = 0
    TRISA = %00000011
    TRISB = 0
    TRISC = 0
    TRISD = 0
    TRISE = 0
    Pause 500
    LCDOUT $FE, 1        ' Clear display, cursor off
    MAINLOOP: ' Here we start a cycle ...
    TMR1on      = 0                     ' Reload the timer ...
    TMR1H       = PRESET.Highbyte
    TMR1L       = PRESET.Lowbyte
    TMR1IF      = 0
    TMR1ON      = 1                     ' Restart the timer
    GIE         = 1                     ' Interrupts authorized
    IF run THEN                         ' Run Button has to be pushed for first move
    FINDPROGRAM:                        'SELECTS BETWEEN SEVERAL TYPES OF MOTION
        ADCIN Selector , TEMP          'READ CHANNEL 10 TO TEMP
        SELECT CASE TEMP
        	Case is <  250
        	 	POSITION = 125
            Case is <= 366
         		POSITION = 150
        	Case is <= 583
        	 	POSITION = 175
        	Case is <= 783
        		POSITION = 200
        	Case is <= 1000
         		POSITION = 225
        	Case is >  1000
         		POSITION = 250
         End Select
        low servo1
        Pulsout Servo1, position
        PLOW = 20000-POSITION
        IF COUNTER.5 OR ! COUNTER THEN
            'HSEROUT ["HIGH =" , DEC POSITION, " LOW =", DEC PLOW, 10,10,13]
            LCDOUT $FE,2 ,"Position = ",dec position,"    ", $FE,$C0,"TEMP = ", dec TEMP,"     "
        Endif
            'HSEROUT ["Waiting for RUN", 10,10,13,"HIGH =" , DEC POSITION, " LOW =", DEC PLOW, 10,10,13]
            LCDOUT $FE,2 ,"Waiting for RUN", $FE,$C0,"Position = ", dec position
    TESTINPUTS:
    Delay = 0
    Button Startstop,1,255,0,Delay,0,jump    ' Button active LOW !!!
    IF RUN THEN COUNTER = counter + 1
    IF counter => 60000 then counter = 0 :goto jump
    stop                                     ' Stop here and wait for interrupt
                                                ' to launch a new cycle
    JUMP:
    WHILE STARTSTOP = 0 : wend
    RUN = ~run
    enjoy ...
