Mine were a little sloped as well. But when I tried to add a resistor, it dropped the voltage down too much for it to detect a pulse. I suppose they would all slope equally, so it should not change things too much. Or, a transistor could be added to boost the voltage.
I did notice that I had my MCLRE_ON on my circuit, but did not show it on the schematic. But you can sort of see it in the picture, with the red wire:
I used
I will test with an extra receiver or two tonight, but you might try changing the osc setting, and MCLRE to what I have above, tying MCL to high, and using no resistors for the receiver in on pin5.Code:@ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_ON & _CP_OFF
Walter
