Modedefs.bas
Results 1 to 10 of 10
Thread: Modedefs.bas
    Nov 2009
    Nis, Serbia
    Default Modedefs.bas
    Hi all,
    I'm new PIC user at the early begin.
    I see I need include Modedefs.bas. WHERE TO FIND AND DOWNLOAD THIS?
    Mrpeja
    This fie is needed under certain circumstances.
    According to the manual of the PBP, the modedefs.bas is needed only when you use commands like serin or serout and have mode names like the T2400.
    Otherwise you do not need to include it.
    Check the book.
    Check the book.
    Talking
    Check the book.
    "Psycho Killer
    Qu'est-ce que c'est
    fa fa fa fa fa fa fa fa fa far better
    Run run run run run run run away
    You start a conversation you can't even finish it.
    You're talkin' a lot, but you're not sayin' anything.
    When I have nothing to say, my lips are sealed.
    Say something once, why say it again?
    Psycho Killer,
    Qu'est-ce que c'est
    Psycho Killer
    Qu'est-ce que c'est
    Run run run run run run run away"
    ---Talking Heads
    Hey, I wonder; doesn't that file come on the CD when you buy PicBasic? Let me go check (dumpity-dumpity-doh - crash)... uh huh, here it is!
    You can download it here: http://store.melabs.com/prod/software/PBC.html
    Well, I usually say once something as much clear I can. If you have seen my post sure you can confirm that.
    Although I do not have to explain why the EXACTLY same post has appeared 2 times, I can't resist.
    At the moment I had some connection problems and while I thought I had posted the eply, it seeme I did not. So I hit the Submit button again. Then I realized that the DSL was down.
    Since there is not an option to remove the second post (Only Moderators/Admins can, and please DO so), we have to tolerate the case.
    Nov 2009
    Nis, Serbia
    Thanks a lot, loannis and mtripoli
    mrpeja
    Nov 2009
    Nis, Serbia
    Hi mtripoli,
    I have buy Pickit 2 starter kit, but there is no Modedefs.bas. Unfortunately I don't have a hundred dollars for PicBasic book from the site you have send to me the link.
    So, I'm on the begin of the problem
    mrpeja
    Where did you download the compiler itself?
    Nov 2009
    Nis, Serbia
    I didn't downloading yet. Only I have Pickit2 and two CDs: Mplab Ide and Pickit starter kit CD
    mrpeja
    You can go here and download the demo version of PBP
    http://melabs.com/pbpdemo.htm
    Or you can try this one. It is free.
    http://www.myamicus.co.uk/
