Code:'PIC18F4550 __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H __CONFIG _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H __CONFIG _CONFIG4L, _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L DEFINE OSC 48 BAUDCON.3 = 1 'SETUP FOR HIGH SPEED. DEFINE HSER_RCSTA 90H DEFINE HSER_TXSTA 24H 'HIGH SPEED MODE BAUD RATE GENERATOR DEFINE HSER_BAUD 38400 DEFINE HSER_SPBRG 38H '38400 BAUD =56 dec DEFINE HSER_SPBRGH 01H HSEROUT ["HELLO",13,10] 'test
The above code works, but when i added the following, it gives out garbage character in hyperterm 38400,E,8,1
DEFINE HSER_EVEN 1
DEFINE HSER_BITS 9
Any idea?
