RTC - code not working - Mel's example
Results 1 to 19 of 19
    malc-c's Avatar
    malc-c Guest
    Well I compiled and loaded this example
    @   __config _HS_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
    DEFINE  OSC 20
    CLEAR
    ;----[LCD definitions]------------------------------------------------------
    DEFINE LCD_DREG  PORTB          ' LCD Data port
    DEFINE LCD_DBIT  0              ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB          ' LCD Enable port
    DEFINE LCD_EBIT  5              '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB          ' LCD Register Select port
    DEFINE LCD_RSBIT 4              '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4              ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4              ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000       ' Command delay time in us
    DEFINE LCD_DATAUS 50            ' Data delay time in us
    'RTC pins on 877a
    SDA	Var	PORTC.4
    SCL	Var	PORTC.3
    ' Allocate variables
    RTCYear	Var	Byte
    RTCMonth Var Byte
    RTCDate	Var	Byte
    RTCDay	Var	Byte
    RTCHour	Var	Byte
    RTCMin	Var	Byte
    RTCSec	Var	Byte
    RTCCtrl Var	Byte
    TRISC= %11111111
    ;DB0 var byte[8]
    CMCON = %00000111                   ' Comparators = off
    ' Initialize LCD
    LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250
    ' Set initial time
    	RTCYear = $10
    	RTCMonth = $03
    	RTCDate = $23
    	RTCDay = $02
    	RTCHour = $19
    	RTCMin = $35
    	RTCSec = 0
    	RTCCtrl = 0
    Gosub set		' Set the time
    Goto mainloop		' Skip over subroutines
    ' Subroutine to write time to RTC
    set:
    	I2CWrite SDA,SCL,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCDay,RTCDate,RTCMonth,RTCYear,RTCCtrl]
    ' Subroutine to read time from RTC
    gettime:
    	I2CRead SDA,SCL,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCDay,RTCDate,RTCMonth,RTCYear,RTCCtrl]
    mainloop:
    	Gosub gettime		' Read the time from the RTC
            ' Display time on LCD
    	Lcdout $fe, 1,hex2 RTCDate, "/",hex2 RTCMonth, "/" , hex2 RTCYear,_
    		"  ", hex2 RTCHour, ":", hex2 RTCMin, ":", hex2 RTCSec
    	Pause 500
    	Goto mainloop
    The correct date and time as per code was shown on the LCD. I then recompiled the melrtc.pbp code and this time I was able to run through the set up menu, and kept the date (today's date) and after the "memorise" was displayed the following was displayed:
    2:59:01 AM
    Wed 25 sep 2013
    I have no idea what's screwing the code up, and as you said, given the age of the file, would of though that this would of been discussed years ago !
    Malc I brought one of those for my easy-pic spent hours and over severals day's thinking it was my code. Which I knew it did work in another project, At the time I was unsure about the code but when I loaded the hex file into my running project everything worked ok. so this led me to the RTC moudle (the one shown in the picture), So I built the curcuit on vero board and that worked percfet, There was one connection I never used, So in the end atfer waisting days hunting I just threw it in the bin and could not be botherd to send it back. I did look at but not found nothing
    Have you tried your own simple circuit ?
    malc-c's Avatar
    malc-c Guest
    Thanks for the reply Chuck,
    To be honest I've not tried breadboarding the chip like you suggest. I'll try that tomorrow and see if it makes any difference. Are you suggesting that there is a flaw with the EasyPIC5 board or just the RTC2 board... If the latter, why does it seem to work with other examples that write once to the module and then read the time back from that point... IMO it seems as if the code is doing strange things. I noticed that if I press the increment button it doesn't decrease by one unit, it seems to jump. Maybe the value on the LCD isn't the actual value that the counter is. EG, the hour displayed on the LCD hasn't refreshed to show the value the code has been set to by the button..
    Malc,
    In the modified version of Melanie's code, you have ...
    IncButton var PORTA.6	' Press to Increment Button
    The 16F877A doesn't have a PORTA.6, and to the program it probably looks like the button is always pressed.
    malc-c's Avatar
    malc-c Guest
    How did I miss that ! (embarrassed smile goes here !)
    I'll re-compile tonight after work and see what happens
    malc-c's Avatar
    malc-c Guest
    Well must be something with the configuration of port A.
    	DecButton var PORTD.0	' Press to Decrement Button
    	SetButton var PORTD.1  'Press to Set/memorise Button
    	IncButton var PORTD.2	' Press to Increment Button
    The above works ! as does
    	DecButton var PORTE.0	' Press to Decrement Button
    	SetButton var PORTE.1  'Press to Set/memorise Button
    	IncButton var PORTE.2	' Press to Increment Button
    Thanks to all those who posted... at least I've proved my hardware is ok, just need to learn how to set up these devices correctly !
    Quote Originally Posted by malc-c View Post
    PORTA ... well, you have ...
    ADCON1 = $0F
    For a 16F877A it should be ...
    ADCON1 = 7
    Unless you want some analog channels.
    malc-c's Avatar
    malc-c Guest
    I'm looking at using the code to set a photo period, ie at a set time, say 11:00 pm lights go off, then at 06:00 am lights come on.
    Is it a simple case of : (not actual code, more logic)
    set off time
    set on time
    I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl]
    If RTCHour=>off time or <=on time then lights off
    Else lights on
