How can I get Timer 1 to overflow every 5 seconds
Results 1 to 6 of 6
    Wink
    The only solution for timer 1 to overflow every 5 sec is to run the CPU clock @ 400 khz ...
    Depends on what you intend to do ...
    but
    IF I detect something
    Do something .... for 5 sec
    Wait for detect.
    Generally is solved by sleep/ wake use of the µP ...
    Mar 2009
    FLA
    thanks scalerobotics and acetronics...I guess I had answer my own question
    "...Can I use Timer0 as another prescaler to Timer1?...
    I guess I could use Timer0 and at overflow set any available pin high then low (generate a pulse) and use it as input (via hardwire) to another timer which would be set to read an external clock (that would be the pulse).
    Thinking out of the box.....
    thanks again
    May 2007
    Just increment/count a variable in the TIMER1 interrupt service routine and you can achieve any interval that you want - from fractions of a second to hours.
    Wink
    Oh, Oh ...
    I had forgotten the 876 timer1 simply could be driven by its own oscillator up to 200 Khz ... ( NOT the CPU Osc @ 20 Mhz !)
    so, no problem ... 32768 Hz are easy to find Xtals !
    note also exist " Gate driven " Timers on numerous chips ( see 12f 683 i.e)
