Did you try this code with mechanical encoder, or normal optical encoder?
With use 4 mecanic rotary encoder with this code (pic18f4550) ?
A question, please? With the following "while" statement, does the program wait there until both encoder pins are high? If so, then you're only detecting one of every four AB transitions when moving continually in one direction, correct?
Code:while (portb.0=0 or portb.1=0):pause 10:wend![]()
Yes I think you are correct, this will only detect from 3 to 0 or 3 to 2. So it does not count in quadrature mode. It could be modified with a few more while loops to detect when it leaves the current state.
-Bert
I think not since there is OR in the WHILE statement.
