New approach to Rotary Encoder
Results 1 to 40 of 91
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: New approach to Rotary Encoder
    This routine should do "Track+" /"Track-" :
    UpOrDn:
    if dir=1 then
        PortB.4 = 0
        pauseus 3850
        PortB.4 = 1
        pauseus 3850
        PortB.4 = 0
        pauseus 660
        PortB.4 = 1
    if dir=0 then
        PortB.4 = 0
        pauseus 4450
        PortB.4 = 1
        pauseus 4400
        PortB.4 = 0
        pauseus 660
        PortB.4 = 1
    And what do we have in there, if not delays... They are quite short (8-10ms in total) but it's still possible that that is what's messing with you.
    I don't know what you intended to do with that latest version though, why do you have two cases with the same value, just put the code for both in one.
    Dec 2008
    Ploiesti, ROMANIA
    This is schematic and code...Maybe I miss something important ...
    @ DEVICE pic16F628A, XT_OSC, WDT_OFF, PWRT_ON, BOD_OFF, MCLR_ON, LVP_OFF, PROTECT_ON
    include "alldigital.pbp"
       Define   OSC 4           ' 4MHz
       CMCON = 7                ' Disable on-chip comparator, PORTA in digital mode
    TrisA = %00011100           ; coloane la RA2, 3, 4 ; randuri la RA1, 0 ,7
    porta = %00011100
    TRISB = %00000000
    PORTB = %00010000
    oldState VAR BYTE
    newState VAR BYTE
    UP CON 1
    DN CON 0
    loop:
        PortA.1 = 0
        newState = PortA & %00011100         ; this is for my hw : 11100 = 28
        PortA.1 = 1
        If newState <> 28 THEN
            If newState <> oldState THEN
                Select Case oldState
                    Case 12
                    If NewState = 20 THEN dir=up
                    If NewState = 24 THEn dir=dn
                    Case 20
                    If NewState = 24 THEN dir=up
                    If NewState = 12 THEN dir=dn
                    Case 24
                    If NewState = 12 THEN dir=up
                    If NewState = 20 THEN dir=dn
                END SELECT
                oldState = newstate
                GOSUB UpOrDn
           pause 15                    ; time for UpOrDn
    UpOrDn:
    if dir=DN then
        PortB.4 = 0
        pauseus 3850
        PortB.4 = 1
        pauseus 3850
        PortB.4 = 0
        pauseus 660
        PortB.4 = 1
    if dir=UP then
        PortB.4 = 0
        pauseus 4450
        PortB.4 = 1
        pauseus 4400
        PortB.4 = 0
        pauseus 660
        PortB.4 = 1
    1) I don't understand why you keep putting those PAUSE statements in there, now you have a PAUSE 15 in there....
    2) There's no GOTO LOOP anywhere so the program will "fall thru" into the UpOrDn routine then hit the RETURN and bad things will happpen. (BTW, Loop is a reserved word in newer versions of PBP, best to get used to not using it.
    3) Try resampling the pins and set oldState when you return from the subroutine, ie (changes in red):
        PortA.1 = 0
        PortA.1 = 1
                    Case 12
                    Case 20
                    Case 24
                END SELECT
                GOSUB UpOrDn
                PAUSE 15                    ; time for UpOrDn
         ' Now resample the encoder and keep the state as oldState
              PortA.1 = 0
             oldState = PortA & %00011100         ; this is for my hw : 11100 = 28
             PortA.1 = 1
    GOTO MAIN
    UpOrDn:
    if dir=DN then
        PortB.4 = 0
        pauseus 3850
        PortB.4 = 1
        pauseus 3850
        PortB.4 = 0
        pauseus 660
        PortB.4 = 1
    if dir=UP then
        PortB.4 = 0
        pauseus 4450
        PortB.4 = 1
        pauseus 4400
        PortB.4 = 0
        pauseus 660
        PortB.4 = 1
    Dec 2008
    Ploiesti, ROMANIA
    Mr. Henrik I must get my hat in front of you ! (Hope G.translate work well !).
    NOW, the code work verry good !!! Only sometimes the command are inversed , but in 9 case of 10 it's ok, so I can live with this...
    Thanks for lost so much time with me ! I am verry grateful !
    Great, finally... Now try removing the PAUSE 15 and see if that improves it further.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks to Mr.Henrik Olsson this code work PERFECT !!! I'm sure I would not have done it without his help !
        PortA.1 = 0
        newState = PortA & 011100
        PortA.1 = 1
                    Case 12
                    Case 20
                    Case 24
                END SELECT
                GOSUB UpOrDn
        PortA.1 = 0
        OldState = PortA & 011100
        PortA.1 = 1
    Goto Main
