New approach to Rotary Encoder
Results 1 to 40 of 91
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: New approach to Rotary Encoder
    ... ok, so work, despite the "non-working" of simulator !
    Next step is to try to make the two coexist (keypad.bas & encoder.bas) .
    First I will build the schematic and making some tests. Thanks again for the huge support !
    Dec 2008
    Ploiesti, ROMANIA
    It's this a viable options of reading encoder AND the others buttons ?
    ;reading buttons on line 0 (pseudo-encoder)
        PortB.5 = 0
        newState = PortA & %00000111
        PortB.5 = 1
        If newState <> 7 THEN
            If newState <> oldState THEN
                Select Case oldState
                    Case 3
                    If NewState = 6 THEN
                    dir=up
                    portb.0 = 1
                    If NewState = 5 THEN
                    dir=dn
                    portb.1 = 1
                    Case 5
                    If NewState = 3 THEN
                    dir=up
                    portb.0 = 1
                    dir=dn
                    portb.1 = 1
                    Case 6
                    dir=up
                    portb.0 = 1
                    dir=dn
                    portb.1 = 1
                END SELECT
                oldState = newState
              Pause 100
    ;reading buttons on line 1
        Porta.4 = 0
        status_2 = PortA & %00000111
        Porta.4 = 1
        select case status_2
                    case 3
                    gosub trackDn
                    case 5
                    gosub mute
                    case 6
                    gosub trackUp
        end select
    ;reading buttons on line 2
        Porta.3 = 0
        status_3 = PortA & %00000111
        Porta.3 = 1
        select case status_3
                    case 3
                    gosub volDn
                    case 5
                    gosub volUp
                    case 6
                    gosub Sursa
        end select
    Goto Main
    Dec 2008
    Ploiesti, ROMANIA
    So far, so god ... Now another problem : how can I separates signals?
    If rotary switch is Up, can't read if TK- or V- are pressed ..
    If rotary switch is in middle position, can't read if MUTE or V+ are pressed ...
    If rotary switch is down, can't read if TK+ or S are pressed...
    LE - I think this work :
        Porta.4 = 0
        trisb.5 = 1
        pause 50
        Porta.4 = 1
        trisb.5 = 0
    Dec 2008
    Ploiesti, ROMANIA
    New code works pretty well ... But, how can I avoid false roller codes ? If I turn up, not always the the code "see" up ; if I turn down, not always the code "see" down ...Sometimes, the commands (Up/Down) are inversed !
    I try to add some "pause" between different commands, but the problem remains.
    No, don't try to slow it down...speed it up. If you have any pauses in there try removing those. If your program is going to do 'other' things as well (which I'm sure it is) then you may need to sample the encoder several times thru out the main loop.
    The reason is because if you are at one state and then turn forward two states but you do it fast enough so that the code doesn't detect the "middle" state, then it looks like you turned one state backwards instead of two forward.
    So, you want to sample the encoder as fast as you can possibly turn it - and then some.
    Dec 2008
    Ploiesti, ROMANIA
    I try both variants, presented in code, but without major improvements.
    ;reading buttons on row 0 (pseudo-encoder)
        PortA.1 = 0
    ;    pause 10
    @   nop
        newState = PortA & %00011100         ; this is for my hw : 11100 = 28
        PortA.1 = 1
        If newState <> 28 THEN
                    Case 12
                    If NewState = 24 THEN
                    dir=up
                    If NewState = 20 THEN
                    dir=dn
                    Case 20
                    If NewState = 12 THEN
                    dir=up
                    dir=dn
                    Case 24
                    dir=up
                    dir=dn
                END SELECT
                oldState = newState
                GOSUB UpOrDn
    Which two variants? I only see one in your previous message.
    In that one you have a PAUSE 10 at the beginning, which is commented out, and also a @NOP. Then you have a PAUSE 100 near the end which is NOT commented out.
