Don't know what to tell you but the code works just fine here.This was executed on an AMICUS18 board with a PIC18F25K20. A wire from RB5 to the pulled up inputs was used to simulate the "encoder", the results are here:Code:HSEROUT ["Program start",13] Main: PortB.5 = 0 newState = PortA & %00000111 PortB.5 = 1 If newState <> 7 THEN If newState <> oldState THEN Select Case oldState Case 3 If NewState = 6 THEN dir=up If NewState = 5 THEN dir=dn Case 5 If NewState = 3 THEN dir=up If NewState = 6 THEN dir=dn Case 6 If NewState = 5 THEN dir=up If NewState = 3 THEN dir=dn END SELECT HSEROUT["oldState: ", DEC oldState, " newState: ", DEC newState, " DIR: ", DEC DIR, 13] oldState = newState Pause 1000 ENDIF ENDIF Goto Main
As you can see, it works.
Have you verified that PortB.5 does go LOW?
Have you verified that you DO get a LOW on RA0,1 and 2 as you rotate the encoder?
Have you checked the datasheet to see if any other peripherals are multiplexed onto the pins you're trying to use? ADC? Comparator?
