New approach to Rotary Encoder
Results 1 to 40 of 91
    Default Re: New approach to Rotary Encoder
    Now we're getting somewhere - that looks like it might work.
    The keypad routine has nothing to do with reading the encoder. Put the GOSUB Encoder in the mainloop, before GOSUB check obviously....
    And again, if it doesn't work then remove the keypad routine untill you get the encoder routine working - THEN try to make the two coexist. There's no guarantee that the encoder code works, I just posted it as one possible idea of how to read that kind of "encoder".
    Dec 2008
    Ploiesti, ROMANIA
    No matter what I do, portb.1 goes high and low .... portb.0 don't change ....
    TRISB = 000000
    PORTB = 000000
    oldState VAR BYTE
    newState VAR BYTE
    DIR VAR BIT
    UP CON 1
    DN CON 0
    oldstate = (porta & 000111)
    Main_Loop:
    gosub Encoder
    gosub check
    goto main_loop
    Check :
    if dir = up then
    portb.0 = 1
    portb.0 = 0
    if dir = dn then
    portb.1 = 1
    portb.1 = 0
    encoder:
    portb.5 = 1
        newState = (porta & 000111)
    portb.5 = 0
    If newState <> oldState THEN        ' Changed from last time?
      Select Case oldState
        Case 1
        If NewState = 4 THEN dir=up
        If NewState = 2 THEN dir=dn
        Case 2
        If NewState = 1 THEN dir=dn
        Case 4
        If NewState = 1 THEN dir=up
      END SELECT
    oldstate=newstate
    Since you have the inputs pulled high and the wiper "grounding" each input as it cycles thru them you can't use 1, 2 and 4 as the states since that "looks for" a '1' on the individual pins. You need to use 3, 5 and 6 instead.
    Dec 2008
    Ploiesti, ROMANIA
    Twillight zone ....
        Case 3
        If NewState = 6 THEN dir=up
        If NewState = 5 THEN dir=dn
        Case 5
        If NewState = 3 THEN dir=up
        If NewState = 6 THEN dir=dn
        Case 6
        If NewState = 5 THEN dir=up
        If NewState = 3 THEN dir=dn
      END SELECT
    Don't know what to tell you but the code works just fine here.
    HSEROUT ["Program start",13]
        PortB.5 = 0
        newState = PortA & %00000111
        PortB.5 = 1
        If newState <> 7 THEN
                    Case 3
                    Case 5
                    Case 6
                END SELECT
                HSEROUT["oldState: ", DEC oldState, "   newState: ", DEC newState, "   DIR: ", DEC DIR, 13]
            oldState = newState
            Pause 1000
    Goto Main
    This was executed on an AMICUS18 board with a PIC18F25K20. A wire from RB5 to the pulled up inputs was used to simulate the "encoder", the results are here:
    As you can see, it works.
    Have you verified that PortB.5 does go LOW?
    Have you verified that you DO get a LOW on RA0,1 and 2 as you rotate the encoder?
    Have you checked the datasheet to see if any other peripherals are multiplexed onto the pins you're trying to use? ADC? Comparator?
    Been said before and I will say it again.
    NEVER TRUST A SIM!
    Dec 2008
    Ploiesti, ROMANIA
    ... ok, so work, despite the "non-working" of simulator !
    Next step is to try to make the two coexist (keypad.bas & encoder.bas) .
    First I will build the schematic and making some tests. Thanks again for the huge support !
