New approach to Rotary Encoder
Results 1 to 40 of 91
    Default Re: New approach to Rotary Encoder
    Like I said earlier, I don't have any experience with that piece fo code but if I'd venture I guess (and I'm pretty certain I'm right) it scans the pins once each time you GOSUB the routine. This means it does NOT scan the pins during the time you GOSUB the encoder routine.
    Does Proteus show that walking zero across the pins at the same time as you do newState = PortB & %00000111 - I'd say no.
    If your inputs are pulled up with resistors then the common/wiper of the encoder must be LOW at the time you read the status of the port. You must understand and remember that the PIC executes the code sequentially, one instruction after another.
    Dec 2008
    Ploiesti, ROMANIA
    Step-by-step I think I begin to understand ...
    The correct hardware it's this.
    The software can be this :
    @ DEVICE pic16F628A, XT_OSC, WDT_OFF, PWRT_ON, BOD_OFF, MCLR_ON, LVP_OFF
       Define   OSC 4           ' 4MHz
       CMCON = 7                ' Disable on-chip comparator, PORTA in digital mode
    include "alldigital.pbp"
    include "C:\PBP\enc_KEY.BAS"
    TRISB = 000000
    PORTB = 000000
    oldState VAR BYTE
    newState VAR BYTE
    DIR VAR BIT
    UP CON 1
    DN CON 0
    Main_Loop:
    portb.5 = 1
    gosub keypadscan
    gosub check
    goto main_loop
    Check :
    if dir = up then
    portb.0 = 1
    portb.0 = 0
    if dir = dn then
    portb.1 = 1
    portb.1 = 0
    encoder:
    portb.5 = 0
        newState = (porta & 000111)
    If newState <> oldState THEN        ' Changed from last time?
      Select Case oldState
        Case 2
        If NewState = 4 THEN          ' Was 1 now 4 = Up
          DIR = up
        ELSE                          ' Was 1 now 2 = Down
          DIR = dn
        Case 4
        If NewState = 1  THEN        ' Was 2 now 1 = Up
          DIR = up
        ELSE                           ' Was 2 now 4 = Down
          DIR = dn
        Case 1
        If NewState = 2 THEN        ' Was 4 now 2 = Up
          DIR = up
        ELSE                       ' Was 4 now 1 = Down
          DIR = dn
      END SELECT
      oldState = NewState
    portb.5 = 1
    The question is : where to put "gosub encoder" ? Inside the "enc_key.bas" (it's keypad.bas addapted to 2 row/3 cols) ???
    Now we're getting somewhere - that looks like it might work.
    The keypad routine has nothing to do with reading the encoder. Put the GOSUB Encoder in the mainloop, before GOSUB check obviously....
    And again, if it doesn't work then remove the keypad routine untill you get the encoder routine working - THEN try to make the two coexist. There's no guarantee that the encoder code works, I just posted it as one possible idea of how to read that kind of "encoder".
    Dec 2008
    Ploiesti, ROMANIA
    No matter what I do, portb.1 goes high and low .... portb.0 don't change ....
    TRISB = 000000
    PORTB = 000000
    oldState VAR BYTE
    newState VAR BYTE
    DIR VAR BIT
    UP CON 1
    DN CON 0
    oldstate = (porta & 000111)
    Main_Loop:
    gosub Encoder
    gosub check
    goto main_loop
    Check :
    if dir = up then
    portb.0 = 1
    portb.0 = 0
    if dir = dn then
    portb.1 = 1
    portb.1 = 0
    encoder:
    portb.5 = 1
    portb.5 = 0
        Case 1
        If NewState = 4 THEN dir=up
        If NewState = 2 THEN dir=dn
        Case 2
        If NewState = 1 THEN dir=dn
        Case 4
        If NewState = 1 THEN dir=up
      END SELECT
    oldstate=newstate
    Since you have the inputs pulled high and the wiper "grounding" each input as it cycles thru them you can't use 1, 2 and 4 as the states since that "looks for" a '1' on the individual pins. You need to use 3, 5 and 6 instead.
    Dec 2008
    Ploiesti, ROMANIA
    Twillight zone ....
        Case 3
        If NewState = 6 THEN dir=up
        If NewState = 5 THEN dir=dn
        Case 5
        If NewState = 3 THEN dir=up
        If NewState = 6 THEN dir=dn
        Case 6
        If NewState = 5 THEN dir=up
        If NewState = 3 THEN dir=dn
      END SELECT
    Don't know what to tell you but the code works just fine here.
    HSEROUT ["Program start",13]
        PortB.5 = 0
        newState = PortA & %00000111
        PortB.5 = 1
        If newState <> 7 THEN
                    Case 3
                    Case 5
                    Case 6
                END SELECT
                HSEROUT["oldState: ", DEC oldState, "   newState: ", DEC newState, "   DIR: ", DEC DIR, 13]
            oldState = newState
            Pause 1000
    Goto Main
    This was executed on an AMICUS18 board with a PIC18F25K20. A wire from RB5 to the pulled up inputs was used to simulate the "encoder", the results are here:
    As you can see, it works.
    Have you verified that PortB.5 does go LOW?
    Have you verified that you DO get a LOW on RA0,1 and 2 as you rotate the encoder?
    Have you checked the datasheet to see if any other peripherals are multiplexed onto the pins you're trying to use? ADC? Comparator?
