New approach to Rotary Encoder
Results 1 to 40 of 91
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: New approach to Rotary Encoder
    Update code :
    Main_Loop:
    gosub keypadscan
    newState = (PortB & %00000111)
    gosub encoder
    gosub check
    goto main_loop
    Check :
    if dir = up then
    porta.0 = 0
    porta.1 = 1
    if dir = dn then
    porta.0 = 1
    porta.1 = 0
    encoder:
    If newState <> 0 THEN
    If newState <> oldState THEN        ' Changed from last time?
      Select Case oldState
        Case 32
        If NewState = 128 THEN          ' Was 1 now 4 = Up
          Q_Count = Q_Count + 1
          DIR = UP
        ELSE                          ' Was 1 now 2 = Down
          Q_Count = Q_Count - 1
          DIR = DN
        Case 64
        If NewState = 32 THEN        ' Was 2 now 1 = Up
          DIR = UP
        ELSE                           ' Was 2 now 4 = Down
          DIR = DN
        Case 128
        If NewState = 64 THEN        ' Was 4 now 2 = Up
          DIR = UP
        ELSE                       ' Was 4 now 1 = Down
          DIR = DN
      END SELECT
      oldState = NewState
    but no matter what M (1,2 or 3) I push, porta.0 goes high and stay so.
    In the first code you posted you read the status of PortB before driving the the common pin for the encoder so there probably won't be any signals comming in.
    In the second, updated example, you never drive the common pin for the encoder at all.
    You need to set the "common pin" high (or low depending on hardware) and THEN read the port otherwise you won't get anything back.
    You really need to sit back and think the problem thru, not just cut and paste pieces of code together without understanding what they do and how the hardware they're intended to interface to is supposed to work.
    Think it thru.... The "encoder" has a "wiper" which "cylces" thru the different contacts. Depending on which contact the wipers is positioned at you'll get a signal out on a certain pin. In order to get that signal out the "wiper" must be "powered" in one way or another. If the inputs from the "contacts" are pulled up then wiper must be grounded so that it pulls the contact (and signal LOW). Likewise if the inputs from the contacts are pulled down then the "wiper" must be high in order to pull the inputs high.
    If the inputs are pulled up with resistors then you'll get a "walking zero" across the three pins, if the inputs are pulled down you'll get a "walking one" across the inputs. You must adapt the code to match.
    My suggestion, for now, is that you ditch the matrix routine untill you get the encoder working - and understand how it works.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for support !
    "In the second, updated example, you never drive the common pin for the encoder at all."
    But ..."keypadscan" don't do this ? Proteus show how "0" walk through portb 3,4,5.
    Like I said earlier, I don't have any experience with that piece fo code but if I'd venture I guess (and I'm pretty certain I'm right) it scans the pins once each time you GOSUB the routine. This means it does NOT scan the pins during the time you GOSUB the encoder routine.
    Does Proteus show that walking zero across the pins at the same time as you do newState = PortB & %00000111 - I'd say no.
    If your inputs are pulled up with resistors then the common/wiper of the encoder must be LOW at the time you read the status of the port. You must understand and remember that the PIC executes the code sequentially, one instruction after another.
    Dec 2008
    Ploiesti, ROMANIA
    Step-by-step I think I begin to understand ...
    The correct hardware it's this.
    The software can be this :
    @ DEVICE pic16F628A, XT_OSC, WDT_OFF, PWRT_ON, BOD_OFF, MCLR_ON, LVP_OFF
       Define   OSC 4           ' 4MHz
       CMCON = 7                ' Disable on-chip comparator, PORTA in digital mode
    include "alldigital.pbp"
    include "C:\PBP\enc_KEY.BAS"
    TRISB = 000000
    PORTB = 000000
    oldState VAR BYTE
    newState VAR BYTE
    DIR VAR BIT
    UP CON 1
    DN CON 0
    Main_Loop:
    portb.5 = 1
    gosub keypadscan
    gosub check
    goto main_loop
    Check :
    if dir = up then
    portb.0 = 1
    portb.0 = 0
    if dir = dn then
    portb.1 = 1
    portb.1 = 0
    encoder:
    portb.5 = 0
        newState = (porta & 000111)
        Case 2
        If NewState = 4 THEN          ' Was 1 now 4 = Up
          DIR = up
          DIR = dn
        Case 4
        If NewState = 1  THEN        ' Was 2 now 1 = Up
          DIR = up
          DIR = dn
        Case 1
        If NewState = 2 THEN        ' Was 4 now 2 = Up
          DIR = up
          DIR = dn
      END SELECT
      oldState = NewState
    portb.5 = 1
    The question is : where to put "gosub encoder" ? Inside the "enc_key.bas" (it's keypad.bas addapted to 2 row/3 cols) ???
    Now we're getting somewhere - that looks like it might work.
    The keypad routine has nothing to do with reading the encoder. Put the GOSUB Encoder in the mainloop, before GOSUB check obviously....
    And again, if it doesn't work then remove the keypad routine untill you get the encoder routine working - THEN try to make the two coexist. There's no guarantee that the encoder code works, I just posted it as one possible idea of how to read that kind of "encoder".
    Dec 2008
    Ploiesti, ROMANIA
    No matter what I do, portb.1 goes high and low .... portb.0 don't change ....
    TRISB = 000000
    PORTB = 000000
    oldState VAR BYTE
    newState VAR BYTE
    DIR VAR BIT
    UP CON 1
    DN CON 0
    oldstate = (porta & 000111)
    Main_Loop:
    gosub Encoder
    gosub check
    goto main_loop
    Check :
    if dir = up then
    portb.0 = 1
    portb.0 = 0
    if dir = dn then
    portb.1 = 1
    portb.1 = 0
    encoder:
    portb.5 = 1
    portb.5 = 0
        Case 1
        If NewState = 4 THEN dir=up
        If NewState = 2 THEN dir=dn
        Case 2
        If NewState = 1 THEN dir=dn
        Case 4
        If NewState = 1 THEN dir=up
      END SELECT
    oldstate=newstate
